Islander 36 projects in paradise!!!!! - Page 5 - SailNet Community
 176Likes
post #41 of 234 Old 01-29-2014
Re: Islander 36 projects in paradise!!!!!
Transducers are not randomly interchangeable. Some depthsounders use the same transducers as others, but you'd have to find out what you have and then find something that uses the same transducer. And if that means a modern head with a 30? year old transducer, I'd expect the odds are slim to none. And of course, you don't know if the one you have works, do you? It could damage a new head unit.
hellosailor is offline
post #42 of 234 Old 01-30-2014 Thread Starter
christian.hess's Avatar
hmmmm may I inquire as to HOW it would damage the head unit?
but I get it and appeciate the help
whish the old head unit ws on the boat
Merit 25 sold...Islander 36 still afloat? who knows...Im still in Columbus, and back...I think...jajajaja!!!!
christian.hess is offline
post #43 of 234 Old 01-30-2014
Asleep at the wheel
jimgo's Avatar
Christian, why not try to find another head unit? Or don't you know what was there?
It's sounding more and more like you need to start an import/export business.
christian.hess likes this.
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #44 of 234 Old 01-30-2014 Thread Starter
yeoup
I beleive the old head unit was signet...
Im having a hard time thinking that transducers at least simple ones are not intercheangable(for example ive seen lowrance and garmin fishfinders use the exact same stern mounted transdcuer so dunno) after all the fampous airmar transducers can be bought and are used on various head units...as are windvanes, speed indicators etc....
anywhoo
Ill try and take a pic...there is bad access to the transducer so maybe reading a name wont work...
anywhoo
post #45 of 234 Old 01-30-2014
Asleep at the wheel
jimgo's Avatar
Some pure speculation, but it may be that the electrical characteristics (impedance versus capacitance) that are used to encode the information and the scale used (e.g., some may say that every 10 ohms of impedance means 1 foot of depth to the obstruction, while others may say 20 ohms per foot) could be different based on the manufacturer of the transducer and/or what the head unit manufacturer specified. The transducers may also have different power requirements, and not all head units may be designed to source that much power. That being said, manufacturers may have realized that standardization of some of these characteristics is good, because it will reduce their costs across the industry. If that happened, whether your transducer is one that used the "winning" combination or not is going to be tough to tell without a lot of research.
Hope this helps.
- Jim
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #46 of 234 Old 01-30-2014
mitiempo's Avatar
Christian
Here is some help:
New Depth Sounder With An Old Transducer Photo Gallery by Compass Marine at pbase.com
Brian
mitiempo is offline
The Following User Says Thank You to mitiempo For This Useful Post:
christian.hess (01-30-2014)
post #47 of 234 Old 01-30-2014
Christian.. I installed a new Raymarine ST40 head on a 25 year old Signet depth transducer.. works great and I gained considerable range to boot.
Faster is online now
post #48 of 234 Old 01-30-2014 Thread Starter
HELL FREAKIN YEAH FASTER!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
im almost positive its a signet since everything else was signet
and old! jajaja
thanks guys really appreciate it
trying to save bucke where I can you know and not punch holes in an otherwise sound boat now!
no water in the bilge is a nice thing! jajajaja
post #49 of 234 Old 01-30-2014 Thread Starter
Originally Posted by mitiempo View Post
gold just gold!
post #50 of 234 Old 02-10-2014 Thread Starter
well nothing major has happened here after plopping the boat back in the water...finshed the port bulkhead and ripped out the head bulkhead that is just structural not attached to any plates...
and I scored a very nice 15hp johnson seahore outboard...that will be my main propulsion for now
till I get somewhere or get somebody to bring me down a nice used engine like an atomic 4.
so
the outboard is in GREAT shape...long shaft and very well taken care of 1977.
its an old 77 but works great, low hours, new impeller and came with a nice metal tank.
Ill be getting a nice solas 4 blade prop(anybody care to help here? need a friendly forwarder jeje) for it so anchoring ans stopping will be improved
I also found out the po used 2 outboard brackets tied together at the wood block to act as one mount...not bad thinking but I need to fix the springs and some rusty bolts that corroded
so thats my news from down here
had some bad work done too, lazy workers not giving a crap and well simply not enough time to be on top of them daily but
we are still at it
decks are finsihed, chainplates are finsihed and even the lifelines and push pull pits have been redone and soldered back into shape and polished the bases ready to be installed with new backing plates.
pics coming soon
at least of the outboard! jajja
peace
Islander 28 vs Islander Bahama 30 vs Irwin Cititation 34 twelch Boat Reviews 42 05-28-2013 11:17 AM
C&C 35' MK II -- Projects Pirate1716 C & C 4 04-13-2009 05:35 PM
Help With Some Projects gpd955 Gear & Maintenance 9 08-02-2006 04:55 PM
