Islander 36 projects in paradise!!!!! - Page 9 - SailNet Community
 176Likes
post #81 of 234 Old 04-25-2014 Thread Starter
christian.hess's Avatar
Re: Islander 36 projects in paradise!!!!!
thanks boss
when the time comes Ill see what I can figure out...for now though its white! jajaja
peace
Merit 25 sold...Islander 36 still afloat? who knows...Im still in Columbus, and back...I think...jajajaja!!!!
christian.hess is offline
post #82 of 234 Old 04-25-2014
The islander windows use a plastic that the manufacturer recommends using dow 795 for installation, other sealants eat at the plastic.
Interested in what you do for a liner, my Islander 28's is pretty worn out
Antibes is offline
post #83 of 234 Old 04-25-2014 Thread Starter
well for sure there was no dow795 on mine...they had already been done or redone before...
interestingly the lenses are all nice and tight inside the plastic frames so its just a matter of sealing the frames back into the cabins at least for now
well see about the liner or not
I definitely DONT want the original type vynil cover as the zippers all failed and honestly you still couldnt access stuff in order to work on it...Id love to glue some wallpaper ish stuff onto it but I still see that as a lot of work right now
anywhoo
post #84 of 234 Old 05-13-2014 Thread Starter
hey some progress! but I need some help guys!
pics first
windows:
they will do for now...I need to go over the actual outer rim to plastic joint as maybe some still leak
they do look much better over white than delaminated ply veneer....thats for sure jaja so Im finally complete cabin wise...
jimgo likes this.
post #85 of 234 Old 05-13-2014 Thread Starter
so this is what I need help on:
my main sheet scenario! we took off some damaged hardware on each side of the traveler, it seems this is what Im missing for my mainsheet to go back to the winches Im guessing starboard side under the dodger since I have 3 winches there and 2 on port
this is my "new" main sheet aka washed in the machine with salvadorean downy! I also whipped the ends...the difference in pliabilty and ease of handling is impressive...I recomend this to any one with old rope on their boats btw
see this little sheave, its mounted on this custom wood block...Im trying to guess the angles here but IM ASSUMING it leads back under the dodger to one of the winches
my question is is this only one side...(the blocks of wood are on both side, but they were pretty damaged...
how would you guys run the mainsheet? this is beleive it or not my first mid boom sheeting system! jajaja
this is the hardware I have upfront...the eye should be for the vang as well as 2 sets of sheaves on each side that allow for it to be adjusted under the dodger...
however Im assuming also the po led all lines aft, so they might be simply for the halyards
Im not going thata route I like my halyards at the mast, I also whipped them new again...
any and all help appreciated!
post #86 of 234 Old 05-13-2014 Thread Starter
last time out I pseudo polished the stanchions...not too shabby for simple kitchen stainless paste they sell at the hardware store....just with a rag...
thats it for now!
post #87 of 234 Old 05-13-2014 Thread Starter
port side winches
and stbd
in this pic I was trying to guess the angle of the mainsheet coming back "using" these blocks on each side of the traveler but Im stumped
maybe Im brain farting here but what other solutions are there here with what I have?
thanks
post #88 of 234 Old 05-14-2014
Asleep at the wheel
jimgo's Avatar
Christian, the sheave looks like it might be for the outer-most winch on the starboard side, and I believe that's for the mainsheet. If you look closely at the pictures of this Islander:
1977 Islander 36 Sail Boat For Sale - www.yachtworld.com
It looks like they run the mainsheet forward to a block at the base of the boom, then down to one of those spring-loaded blocks in your picture, then out to the sheave in question, then back to the winch.
christian.hess likes this.
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
The Following User Says Thank You to jimgo For This Useful Post:
christian.hess (05-14-2014)
post #89 of 234 Old 05-14-2014
Asleep at the wheel
jimgo's Avatar
This one shows another way of doing it:
1974 Islander 36 Sail Boat For Sale - www.yachtworld.com
If you look at the 7th picture, just before the interior shots, you'll see how they did it.
- Jim
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #90 of 234 Old 05-14-2014 Thread Starter
thanks man! I have been pondering pics all last night...
it does seem its this way but they go down to the deck...
not to one of the sheaves on the wood block at the end of each side of the traveller
Im brain farting on what those would be for? The good news is it doesnt look like I need them for now!
It looks like the same goes for whatever boom vang I setup, it looks like it goes on port side...down to the deck sheaves and back to the port side winches...
thanks so much man!
jimgo likes this.
Islander 28 vs Islander Bahama 30 vs Irwin Cititation 34 twelch Boat Reviews 42 05-28-2013 10:17 AM
C&C 35' MK II -- Projects Pirate1716 C & C 4 04-13-2009 04:35 PM
Help With Some Projects gpd955 Gear & Maintenance 9 08-02-2006 03:55 PM
