WTH are these things? - Page 2 - SailNet Community
 2Likes
post #11 of 17 Old 01-09-2014
Send a message via Skype™ to LaurenceU
Re: WTH are these things?
Originally Posted by SchockT View Post
Are there cleats aft of the leads? If the boat was once rigged for a spinnaker they could be leads for a double ended foreguy.
the leads at 12' back (probably the max beam) could be used for a barber hauler for the spinnaker sheets.
Laurence
LaurenceU is offline
post #12 of 17 Old 01-09-2014
Senior Moment Member
SloopJonB's Avatar
Guys - it's a Windrose 22 - think cheapest possible solution to a minimum sailing configuration.
I doubt there has EVER been one with a spinnaker barber hauler setup.
Econo small boats frequently have bulldog fairleads for sheet leads where a more substantial boat would have track & blocks.
My first 20' was set up exactly that way.
SloopJonB is offline
post #13 of 17 Old 01-09-2014
bljones's Avatar
sheet blocks 6' from the bow?
It's 5 o'clock somewhere:
bljones is offline
post #14 of 17 Old 01-09-2014
4KSB driver.
Jib sheet block, and Genoa sheet block.
1983 WD Schock Wavelength 24. Production boat limit tester, blue-water bucket owner, with wine taste on a beer budget.
SHNOOL is offline
post #15 of 17 Old 01-09-2014
bljones's Avatar
someone might be onto something with sheet leads, judging by this pic:
Although it strikes me as a damn goofy set up, with some horrible sheeting angles,
bljones is offline
post #16 of 17 Old 01-10-2014
Sailor
Gladrags1's Avatar
I think they are for double line furling control lines. You would have a continuous loop necessitating 2 lines being fed back to the cockpit. I might have the name wrong but not the function.
Tod
Mandolin
Bayfield 36
Sailing out of Rock Creek, Chesapeake Bay
Gladrags1 is offline
post #17 of 17 Old 01-10-2014
I have close to the same set up on my 26 ft "cheap" sailboat. I use the forward ones when I have my storm jib up and the aft ones when my genoa is being used. They seem to have been placed in the best spot possible for use with the 2 sails and seem to work very well. Keep in mind I'm not racing and have nothing to prove. Just like to get out on the water and sail. Bigger and more precise boats have a track so the point can be adjusted depending on what sail is being used.
ABH3 Boyer is offline
WTH is up w/ the spotlight? sailordave General Discussion (sailing related) 26 08-30-2013 01:17 AM
WTH!!!!!!! Silicone problem.. deltaten Gear & Maintenance 18 03-08-2013 11:18 PM
WTH Chuckles? A freakin' mono???? smackdaddy General Discussion (sailing related) 50 09-25-2012 09:08 AM
Heave to, WTH? T37Chef Seamanship & Navigation 30 10-08-2010 08:10 AM
