Batten Replacements? - Page 2 - SailNet Community
 3Likes
post #11 of 16 Old 01-10-2014
Re: Batten Replacements?
Check with the racers in your area, I bet they have plenty of extra battens. We have 4 or 5 sets we never use.
Rob
RobertMw is offline
post #12 of 16 Old 01-10-2014 Thread Starter
ericb760's Avatar
Originally Posted by fallard View Post
Full length battens are costly, but the short battens found in many boats are very affordable. You may not notice the difference as a newbie/non-racer, especially with older, stretched ("blown-out") sails, but battens help keep a smooth trailing edge shape to your sails. This not only provides for better airflow (less turbulence), but also minimizes the flutter in your leech, thereby extending the life of your sail.
The only "cons" I can think of is that they are not free and that you need to assure they are properly captured in the batten pocket.
All four of mine are different lengths depending on which batten sleeve they fit in, but are not "full battens". I don't have a picture, but they all slide in and then drop down an inch or so to hold them in.
ericb760 is offline
post #13 of 16 Old 01-10-2014
mitiempo's Avatar
Originally Posted by ericb760 View Post
Hardly. But when a 5 cent screw costs $1.50 at WM because it's "marine grade", I call foul.
I'm hardly a West Marine fan. I'm at their competition in Victoria. They're not very good competition though - the West Marine employees are quite lonely and we are very busy.
I find it hard to believe though that West Marine can actually get 1.50 for a screw (what size?) in your area with the competition they must have - after all there are quite a few marine stores listed in the Long Beach yellow pages.
Brian
mitiempo is offline
post #14 of 16 Old 01-10-2014
If hollow-leech battenless sails really were the cat's meow everybody would be doing it.
While it's true that most new boats nowadays come with battenless mains, that's more about the ubiquitous in-mast furlers than any perceived advantage of going battenless beyond that.
mitiempo and ericb760 like this.
Faster is offline
post #15 of 16 Old 01-11-2014 Thread Starter
ericb760's Avatar
There are fewer than you think. Most are mom and pop chandelries (sp) and are located within wealthy marinas, thereby making their prices even higher than WM. For marine hardware, I generally hit the used/consignment shops in San Pedro. But, you can never be guaranteed that you'll find the exact part that you're looking for. Minnie's is a bit of a drive, but if you are willing to dig through boxes of hardware, you can usually find what you're looking for there. Also a great place to find used sails, which I do not need, but will keep for future reference.
ericb760 is offline
post #16 of 16 Old 01-11-2014
If hollow-leech battenless sails really were the cat's meow everybody would be doing it....
Its not cat's meow, its not sophisticated, and not for everyone. If racing or that 1.8 of a knot is essential, then by all means have as much sail area as you can, after all, you always go back to your dock and are near a sailmaker.
But for long term cruising, you may opt for simplicity. Sail maintenance is largely chafe repairs, and more often than not, batten pockets. You loose the roach but gain in other ways. I have cruised extensively with a battenless main. You don't loose much sail area by removing the roach, does not compromise on-the wind performance and sometimes help to reduce weather helm. Its easier to hoist and you can reef on any point of sail. You need a properly cut and constructed sail. Do your research and then choose your option according to the type of sailing you intend to do.
SVTatia is offline
window replacements jasonr575 Gear & Maintenance 2 11-17-2013 03:10 PM
Replacements for old instruments? Dave_E Gear & Maintenance 6 08-19-2013 06:20 PM
Looking for window replacements for 22'USY empaynejr General Discussion (sailing related) 0 07-08-2009 02:17 AM
Port hole replacements syon Gear & Maintenance 15 06-09-2008 01:29 AM
Full Batten or Partial Batten Main? BlowinSouth Gear & Maintenance 27 11-16-2007 07:33 PM
