New Magma ceramic coated nested cookware - Page 2 - SailNet Community
post #11 of 18 Old 01-11-2014
no longer reading SailNet
Alex W's Avatar
Re: New Magma ceramic coated nested cookware
Originally Posted by Gladrags1 View Post
I am curious, why would you not buy Teflon again?
I didn't buy teflon for my pot set because it isn't durable and is unhealthy if overheated. It's unlikely to get hot enough to be unsafe on my boat's alcohol stove, but it isn't worth chancing it.
The only pan that I want as non-stick is a frying pan, and the Magma set doesn't include a good one anyway. So I keep a cast iron pan on the boat.
Alex W is offline
post #12 of 18 Old 01-12-2014
bjung's Avatar
How does ceramic coated cookware hold up? I found that stacking will scratch coated cookware, especially on a boat with constant movement. Would be nice to find non-stick that doesn't scratch as easily and remains non-stick. Any long term experience with ceramic coated?
bjung is offline
post #13 of 18 Old 01-12-2014
As far as stacking scratching, just stack towels between the pans, which will alternatively also be a storage medium for the towels
Multihullgirl is offline
post #14 of 18 Old 01-12-2014
Our cuisinart SS nesting set has done very well. 2 years part time and over 2 years of full time cruising
xort is offline
post #15 of 18 Old 01-12-2014
mitiempo's Avatar
The ceramic coated cookware stands up well, is a lot tougher finish than teflon. Nowhere near as non stick as teflon though.
Brian
mitiempo is offline
post #16 of 18 Old 01-12-2014
MikeOReilly's Avatar
As I say, our teflon Magma stacking set has held up just fine over seven years of seasonal (but heavy) use. As Multihullgirl says, just insert a small cloth between the pots when storing. Anything small, soft and insulating. Those blue disposable oil paper towels work get.
Just take a small bit of effort to keep the teflon in fine shape.
Why go fast, when you can go slow.
MikeOReilly is offline
post #17 of 18 Old 01-12-2014
No more curry buffets
Ritchard's Avatar
I have the Magma 7 piece stacking set in stainless as well. As someone said above, I think they are an amazing bargain compared to department store "better" cookware. You get a pretty robust set of pots for the price. I've never felt the need for non-stick, but we don't fry much on the boat.
Bashing about on Lake Ontario and Beyond
"Ariel" '79 Endeavour 32
Ritchard is offline
post #18 of 18 Old 01-12-2014
JimMcGee's Avatar
We got our Magma non-stick set in either 2009 or 2010 and it's held up very well. More importantly these pans cook well, with heavy copper clad bottoms for even heating.
The lids are contoured to prevent the nested pans from rubbing, and I secure them with a bungee (don't remember if it was included). Our set gets used most weekends from April through October. Best of all the whole nested set fits nicely in the oven so it frees up cabinet space.
We added a stainless steel chef's pan for steaks and chicken when you want that "sear".
95 Catalina 30 Island Time
The sail, the play of its pulse so like our own lives: so thin and yet so full of life, so noiseless when it labors hardest, so noisy and impatient when least effective." - Henry David Thoreau
JimMcGee is offline
Stainless -vs- Aluminum Cookware hriehl1 Gear & Maintenance 45 03-07-2014 02:38 PM
Ceramic Knife davidpm Gear & Maintenance 29 01-14-2013 03:19 AM
Cast Iron Cookware turfguy Provisioning 36 12-17-2008 08:25 PM
lifelines-coated vs non coated Gulfislander Gear & Maintenance 32 01-18-2008 04:35 PM
Epoxy and ceramic drynoc Gear & Maintenance 0 12-27-2005 11:43 AM
