New Magma ceramic coated nested cookware - SailNet Community
post #1 of 18 Old 01-09-2014 Thread Starter
Mondofromredondo
All,
I'm not affiliated first of all.
Just recieved their newly released 10 pc ceramic over stainless nestable cookware set. Very heavy / high quality units. Also Ceramic coating vs teflon coating of the older units seems to me to be a large improvement.
I was worried they'd feel cheap and overly light. Instead each piece is heavy and well built. The detachable handles that allow for nesting also are well made. But best of all they all nest together (except the 2 handles) and will store in a remarkably small space. So only need to make fast (1) item which is the entire cook set. So now thats one more thing off my list.
Keith Campbell
S/V Charity Rose
'88 PSC 34'
mondofromredondo is offline
post #2 of 18 Old 01-09-2014
Re: New Magma ceramic coated nested cookware
A10-366-IND $280.00
That actually looks like it nests well. Is it good quality? I never realized that Magma made cookware. (and the other stuff, stabilzer?)
benesailor is offline
post #3 of 18 Old 01-09-2014
no longer reading SailNet
Alex W's Avatar
I have the 7pc stainless set. It is very high quality, at roughly $100 for the set it is actually a bargain compared to most department store sets.
My only complaint is that I'd prefer a slightly different mix of pots and pans.
The 7 pieces are:
* a roughly 5qt pot
* a roughly 2qt pot
* a high wall frying pan, that is more like a high surface area saucepan
* handle
* two lids
* storage cord
The high sided frying pan isn't that useful of a shape for pancakes or eggs (the two primary things that I fry on the boat) and I could use another saucepan in the 1-2qt size range. A smaller sidewall frying pan would also make the set more compact (that frying pan becomes the lid for the 4qt pan when it is all packed).
I extended mine with a 1.5 liter nesting camping pot from another source and a cast iron frying pan (the hardest item to store in my galley).
Alex W is offline
post #4 of 18 Old 01-09-2014
I guess that answered my question about the stainless. I usually don't like the non-stick, just because i find that it doesn't hold up in the long run.
post #5 of 18 Old 01-09-2014
mitiempo's Avatar
The Magma cookware is a great space saver.
But if the ceramic non-stick is like other brands it is nowhere as good as the non-stick used on brands like T-Fal. I have a Henckels ceramic non-stick frying pan and while it is very well made food does stick and it is harder to clean.
I also agree the compromises made to allow stacking do made for odd sizes and shapes.
Brian
mitiempo is offline
post #6 of 18 Old 01-10-2014
paulk's Avatar
We race, so our nesting cookware is aluminum from EMS because it's lighter. The Magma grill only comes aboard for cruises.
paulk is offline
post #7 of 18 Old 01-10-2014
MikeOReilly's Avatar
We've had our Magma cook set for probably seven or eight years now. I think I bought it when they first came out on the market. Have loved them ever since. They are real SS pots/pans, with heavy aluminium heat disperser bottoms. They store in a small space (nested), and cover most of our cooking needs (two people on board for a month at a time who love to cook).
We have the teflon version. I probably wouldn't buy teflon today, although the non-stick is very handy. In any case, our teflon pots have stood up just fine. Does require that you use plastic or wood utensils, and take minimal effort when stacking them, but our teflon is holding up just fine after all these years.
Anyway, I love the pots. Would definitely purchase again.
Why go fast, when you can go slow.
MikeOReilly is offline
post #8 of 18 Old 01-11-2014
Sailor
Gladrags1's Avatar
I am curious, why would you not buy Teflon again?
Tod
Mandolin
Bayfield 36
Sailing out of Rock Creek, Chesapeake Bay
Gladrags1 is offline
post #9 of 18 Old 01-11-2014
Hi Tod. Mainly b/c there are more rugged non-stick options available now. When I bought our set it was teflon or plain SS. I went with the teflon, and as I say, they've held up just fine. They do require a bit more awareness when using them, but I've got no complaints, and have no plans to change our set (and we are about to become full time liveaboards).
Nothing wrong with the teflon as long as you treat them properly.
post #10 of 18 Old 01-11-2014
another option is the Cuisinart nesting set which you can sometimes find in the used market arena. I like mine.
Multihullgirl is offline
Stainless -vs- Aluminum Cookware hriehl1 Gear & Maintenance 45 03-07-2014 02:38 PM
Ceramic Knife davidpm Gear & Maintenance 29 01-14-2013 03:19 AM
Cast Iron Cookware turfguy Provisioning 36 12-17-2008 08:25 PM
lifelines-coated vs non coated Gulfislander Gear & Maintenance 32 01-18-2008 04:35 PM
Epoxy and ceramic drynoc Gear & Maintenance 0 12-27-2005 11:43 AM
