-   -   Prepping to re-bed stanchions. (http://www.sailnet.com/forums/gear-maintenance/116209-prepping-re-bed-stanchions.html)
utchuckd 01-09-2014 06:45 PM
Need to re-bed my stanchions/pushpit as I have been getting some water through the holes. When I take them off, how do I know what, if anything, I need to do to the hole locations before I reinstall them? If the core is wet do I need to see if it will dry out?
benesailor 01-09-2014 06:59 PM
Re: Prepping to re-bed stanchions.
Is there even core where your stanchions attach? It may be solid fiberglass. I'm unfamiliar with o'day construction.
utchuckd 01-09-2014 07:37 PM
Yes, there is. According to the hole for my stern light wire it looks like 1/2 or 3/4 inch plywood?
chuck53 01-09-2014 08:02 PM
Here's what I did when I rebedded my stanctions on a boat I had some years ago...
Most boats do have wood cored decks. I took my power drill, put a finishing nail in the chuck with about 1/2" of the nail bent 90 degrees. Put the nail in all the holes and turned on the drill basically opening up the core and not making the holes in both layers of fiberglass any larger. After that, I filled the enlarged holes with epoxy. After that dried, I redrilled the holes. After remounting my stanctions, I knew if any water did leak thru, it would only come in contact with hardened epoxy and never soak into the wood core.
Alex W 01-09-2014 08:57 PM
Re-Bedding Deck Hardware With Bed-It Butyl Tape Photo Gallery by Compass Marine at pbase.com
That has the "do it right" solution.
I did the "almost right" solution, which was everything there except for potting the core with epoxy. I feel pretty confident that counterbored holes and good butyl tape will keep the core dry for 20+ years, the previous sealant and counterbored holes did so for the 25 years.
utchuckd 01-09-2014 11:42 PM
Thanks. Is potting the holes necessary or just recommended? I've never worked with epoxy before.
mitiempo 01-09-2014 11:57 PM
It is the only way to guarantee that the core doesn't get wet. When core gets wet it doesn't remain in the area of the hole but eventually travels over a wide area. This is more common with plywood core than balsa core as the plies allow a path for the water to travel along the grain. The reason so many boats have wet core issues is because the builders didn't pot the holes properly to begin with. All fittings need re-bedding eventually or water will enter. This is especially true of stanchion bases and chainplates, the items that move the most from loads put on them. Butyl is in my opinion the best bedding compound and my deck has not had issues with water where butyl was used by CS when the boat was built. But my stanchion bases are not in cored areas.
I would definitely suggest potting the holes with epoxy. It is easy as shown in the link above. At the same time it would be a good idea to see if larger backing plates can be added to stiffen the deck in the area of the stanchion bases.
christian.hess 01-10-2014 12:14 AM
I just got back from doing this for my chainplatye holes(look ate islander 36 project thread) and its easy...its very important to bevel and file the holes and if you can dry out a bit...
I just rebedded my aft lower backing plates...Im doing it in 2 stages, from below and from above...since they have those funny metal cover plates....
in any case I potted the main chainplate holes and bulkhead holes...not the aft lowers since they are easily serviced so I plan to check them every 6 months or so...
cheers
ps. you can also brush on thickened epoxy,,,you dont have to completeley seal the hole and redrill...just a swipe to seal off the wood...the lightly file away
redrilling same size holes never works out...always go big, pot then drill exact size
cheers
pauloman 01-10-2014 10:22 AM
good advise above but use an epoxy that can bond to posible damp surfaces and is reinforced with fiber/kelvar etc. for strength. Google/Bing Wet Dry 700 epoxy
note that you can insert greased screws/bolts into wet epoxy. When the epoxy cures you can un-screw the bolts and have a threaded/tapped hole.
arf145 01-10-2014 10:27 AM
A cordless Dremel with a little cutter bit (#115) to clear out a few millimeters of core all around inside each hole before filling with thickened epoxy has worked well for me. And if it's wet in there and has soaked into the wood, I wouldn't count on significant drying taking place really.
Copyright ©2000 - 2016, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging v3.1.0 (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
