An indelicate question - SailNet Community
 4Likes
post #1 of 19 Old 01-10-2014 Thread Starter
DearPrudence's Avatar
My wife and I enjoy sailing Lake Eire's islands. Each year,(3 now) we set modest goals designed to improve our skills and build confidence. Last year, one of our goals was to spend some time on the hook. Overnight at first then gradually building to several days. A goal that was not met.
Our boat is an '86 Catalina 30. No dinghy, no refrigeration and the stove was pulled by the PO in favor of a 120v refrigerator. No of which scares me. My "indelicate" question concerns the head. It's a hand pump Jabsco. I replaced the tired unit with a new one the first year. I've seen these on newer and more expensive boats so they must work, right? Ours has never been "put to the test" so my question is: How well do they work? I don't know if that tiny little thing is up to the challenge. And are they set up properly on the Catalina 30? (two questions, really )
Thanks
DearPrudence is offline
post #2 of 19 Old 01-10-2014
Re: An indelicate question
I wouldn't call them top of the line, however, a virtually brand new one should work fine. Indelicate is using a 5 gal bucket.
Your only issue should be having sufficient holding tank space to last the duration. To keep waste lines from smelling, you must flush sufficient clear chase water to rinse them out.
Jeanneau 54DS
Minnewaska is offline
post #3 of 19 Old 01-10-2014
"Anhinga" St. Augustine
Capt.Alex's Avatar
They work very well. The key to reliable operation is to flush often. I tell my guests to flush after every "splash". Don't park yourself on it with the New York Times for 20 minutes then get up and expect a miracle. Also if its not TP, or something you have previously eaten, don't try and flush it. Worst case scenario...5 Gal bucket for backup.
Capt.Alex is offline
post #4 of 19 Old 01-10-2014
The most female moderator
Donna_F's Avatar
Dock
Agreed. You'll be fine. We have a C30 and don't feel that the holding tank or the head are inadequate for the sailing that we do or that they are set up improperly. The head has survived many of our non-sailor guests as well as the Womanship instructors and students who used the boat before we bought it.
I suggest that you pump out as frequently as possible. Sometimes I keep the seacock closed which forces the clean sink water to flow into the head and I use that to flush. Cuts down on odors somewhat.
One modification we're doing this year is to drill another vent hole in the stanchion into which the holding tank vent hose runs. Also, make sure that you keep that hose clear. We blew out some critters that had made a home inside the hose causing it to be blocked which could have caused the tank to implode.
Donna
Catalina 30 TRBS
Rock Hall, MD
KB3ZCB
Donna_F is offline
post #5 of 19 Old 01-10-2014
paulk's Avatar
Indelicate would be a coffee can. 5 gallons is like a Cadillac. As suggested, flush with enough water. With our 30+ year old head (which needs to have some pump washers replaced again...) we find that adding water to the bowl puts less strain on the intake pump and makes flushing quicker. Don't be surprised if your holding tank fills quickly, though. For the two of us, our tank needs pumping about 1.5 times a week. (It's a small tank - we race.)
paulk is offline
post #6 of 19 Old 01-10-2014
denverd0n's Avatar
People have been using marine heads for decades with precious few problems. Do a search on the subject and you'll find more than you would ever want to know about how to use it, and insure that it will give years of service.
Personally, I would say there are three major issues that you need to attend to--odors, clogs, and adequate flushing. Luckily, these are dealt with fairly easily.
Adequate flushing has been mentioned a couple of times already. Just be sure you (and guests) understand that you need to flush enough water through the system not just to empty the bowl, but to flush everything all the way through the hoses and into the holding tank.
When it comes to odors, the number one cause is inadequate venting. Be sure the vent is clear and consider adding additional venting. The more air you get into the holding tank, the less problem you will have with odors.
As for clogs, the overwhelming majority happen when people put things in the head that don't belong there. Most people try too hard to be "delicate" when explaining how to use the head. They dance around the issues, especially with guests, leaving openings for confusion and different interpretations. I lay it on the line, in no uncertain terms. What I tell guests is that they may put four things, and four things ONLY, into the head:
1. water
2. urine
3. feces
4. the TP that I have provided (and try to use as little of that as will do the job)
ABSOLUTELY NOTHING ELSE IS ALLOWED IN THE HEAD! You don't throw up in there, you don't toss trash in there, you don't spit in it, or toss kleenex in it, and you very definitely do not put any other sort of wipe or sanitary napkin in there. Those four things and nothing else.
Good luck.
denverd0n is offline
post #7 of 19 Old 01-10-2014
Irrationally Exuberant
I know what you're saying...That hole and hose look mighty small. However, even a hand pump Jabsco pulls and pushes with quite a bit of pressure and forces improbable output down the line. Good to have a rebuild kit handy though for that sad day when things stop working
Tom K
2000 Beneteau 331
Northern Chesapeake Bay
arf145 is offline
post #8 of 19 Old 01-10-2014
MarkofSeaLife's Avatar
Dock
Jabscos are fine.
Why dont you just go anchor for a week, eat and drink normally, and by the end of the week you will understand the fine details of this fine machine. you may even get to love it and sing the jabsco song:
"I love my little Jabsco,
Its so neat for me to pee...."
Etc for 37 verses
rugosa likes this.
Sea Life
Notes on a Circumnavigation:
MarkofSeaLife is offline
post #9 of 19 Old 01-10-2014
Glad I found Sailnet
Bene505's Avatar
Originally Posted by denverd0n View Post
...What I tell guests is that they may put four things, and four things ONLY, into the head:
1. water
2. urine
3. feces
I'd add: "For people that use a lot of toilet paper, it's no problem, just wrap it up and put it into the trash instead."
Regards,
Brad
Great minds discuss ideas;
Average minds discuss events;
Small minds discuss people.
The best minds discuss sailing (and a little bit of politics). I don't know why. It's a mystery!
Bene505 is offline
post #10 of 19 Old 01-10-2014
Bene505's Avatar
Originally Posted by MarkofSeaLife View Post
Jabscos are fine.
Etc for 37 verses
It's so neat for me to pee.
I show it to hot women
Then they want to sail with me.
Sometime two at a time.
Sometimes only one.
No matter how many gals
We always have much fun.
And my head may hurt from wine.
My head may get confused.
But my HEAD she keep a-working
No matter how much it's used.
---chorus ---
Oh Jabsco I love you.
You hook me up onboard
Just like a Margarita
Does the trick on shore.
200 miles offshore
In the nastiest of weather
My Jabsco satisfied
A Floridian name Heather.
She had eaten 3 burgers
Then a sumptuous dinner
While complaining to me
That she wasn't getting thinner.
Then I showed her my Jabsco
To easily lose 10 pounds.
So she dropped the seat
And flushed it all down.
(For we always leave the seat
Without creating a stir
Not up for him
Or down for her.)
She came out of the head
With a smile on her face
With a satified look
For my boat, my place.
---chorus ---
Just like a Fuzzy Navel
Out in the gulf stream
Big, square waves and windy
I was headed to Europe
With a buxom girl named Mindy.
(Now I'm the captain
And I let the girls know IT!
I give all the orders
And I don't take no ****!
But she was so good
I let her do the bossing
And I didn't kick her off
For this long ocean crossing)
Between shifts and watches
Love making and doting
She had that stern look
Like her back teeth were floating
We opened the head door,
Didn't heave-to or stop,
Then she jumped back in bed
With a flat-bellied flop.
----chorus ---
Just like a Sundowner
We've all heard it before.
It wasn't said on a whim.
Girls don't lie down
In boats they can't stand-up-in
Buy my Jabsco changed that
On my little tub.
500 bucks a month.
And it's time for a back rub!
---chorus ---
Just like a Painkiller
Regards,
Brad
arf145, bljones and MarkofSeaLife like this.
Bene505 is offline
The Following User Says Thank You to Bene505 For This Useful Post:
MarkofSeaLife (01-11-2014)
question of those that knows enriquesboat General Discussion (sailing related) 2 10-03-2011 04:15 AM
Simple question, but still a question:keel repair eckcn17 Gear & Maintenance 9 03-16-2011 11:01 AM
Keel/ballast Question?? Plus Extra Credit Question ;) stephenronning General Discussion (sailing related) 2 03-20-2009 07:25 AM
Right of way question alecs123 General Discussion (sailing related) 67 09-09-2008 09:59 PM
question spazomatic General Discussion (sailing related) 9 09-06-2007 10:33 AM
