Low friction rings for single-line reefing - Page 2 - SailNet Community
 16Likes
post #11 of 32 Old 01-10-2014
outbound's Avatar
Re: Low friction rings for single-line reefing
Have single line on first two reefs and double on third. Built boat and main to accommodate. Have blocks sewn into sail. Using dyneema/spectra lines. Deck set ups have minimal angles for bends and good blocks. Jeff is right you need to do everything possible to decrease friction. But with Dutchman I can hoist,reef and strike myself without leaving the cockpit. Unlike in boom I can go to a reach or stay on a beat trim the jib ease the main sheet reef and resume course without need to wake anyone. On single line reefs can shape a bit with halyard tension and not pulling reef way tight. More so then I would get from in boom. Have power on all winches but grind the last few inches when worrying about over tensioning.
Spaghetti is longer but less lines. Dump under hard dodger so non issue. Everything runs through clutches so winches left free. ( usually leave main sheet on winch with clutch open).
Don't like in boom.if you lose halyard whole sail pores on deck and would be uncontrollable for me.
Don't like in mast.have had jams and too much excitement.
So far single on first two and double on third has been just fine.
christian.hess likes this.
s/v Hippocampus
Outbound 46
outbound is offline
post #12 of 32 Old 01-10-2014
christian.hess's Avatar
thats kind of what I have liked and done too
good stuff
Merit 25 sold...Islander 36 still afloat? who knows...Im still in Columbus, and back...I think...jajajaja!!!!
christian.hess is offline
post #13 of 32 Old 01-10-2014
RichH's Avatar
Here's a simple solution for less friction in reef cringles, both single line and double line systems: Goļot roller reefing insert cringles http://www.goiot.com/pdf/p48a.pdf
fred1diver likes this.
RichH is offline
post #14 of 32 Old 01-10-2014
This is a very interesting discussion, as I installed a two line-per-reef system last year.
The tack lines go up to a Gargauer block attached to the tack, then back down and back to the cockpit. This gives a 2:1 purchase at the tack. This works great with very little friction.
The clew lines just go through the clew eye, and there is more friction than I'd like. I tried a block there, but you could no longer pull the clew down far enough. A block with its associated piece of line attaching it to the clew, was too long overall.
I wonder if these low friction eyes would work instead?
Edit : just saw the Gioits, very cool
MarkSF is offline
post #15 of 32 Old 01-10-2014
GeorgeB's Avatar
RichH, do you have experience with the Goiot roller cringles? I have seen adds for them over the years and have been intrigued but would like to get a testimonial before I pull the trigger. I have been pretty happy with the single line reefing set up on my 34. My biggest point of friction has been the (reefing) tack cringles. (Not so much a problem on the clew reefing cringles). I have tried the micro block and ring thing but the block has a nasty habit of flipping over and twisting the reefing line resulting in a heck of a lot more friction. The Goiot cringle, if it works, would be a perfect solution to my friction problem.
George B
2000 Catalina 34 MkII
Alameda, Ca.
GeorgeB is offline
post #16 of 32 Old 01-10-2014
Tim R.'s Avatar
My main has single line reefing with special blocks that get sewn right to the sail. Low fiction and works great.
Tim R.
Our Carina is for sale
1997 Caliber 40LRC
Tim R. is offline
post #17 of 32 Old 01-10-2014
It seems, at least on my setup, that to get the mainsail fairly flat requires the ability to pull the clew right down to the boom. So only a block fixed right to the sail would work.
MarkSF is offline
post #18 of 32 Old 01-10-2014
no longer reading SailNet
Alex W's Avatar
MarkSF: You can make the dogbone quite short and achieve that with an Antal low friction ring. I'm using a longer soft shackle for my dogbone because that gives me the ability to also hook the stainless side onto the reefing hook.
The typical way to do these dogbones is with a piece of sewn webbing. Look at a high quality sail and you'll probably see them on there.
Alex W is offline
post #19 of 32 Old 01-10-2014
Yes the tack has a webbing dogbone, with rings on each end. I simply attached the block to the ring. The length of the webbing is not an issue at the tack.
But at the clew it would be - I really need to get the clew right down to the boom.
MarkSF is offline
post #20 of 32 Old 01-10-2014
My clew line go through the eye like this, don't think that using low friction rings would help much here.
knuterikt is offline
single line reefing question blakeyoung General Discussion (sailing related) 7 02-17-2013 10:54 PM
single line reefing outbound General Discussion (sailing related) 6 12-20-2012 07:23 AM
single line reefing LS2009 Gear & Maintenance 3 09-22-2010 10:46 AM
Line Choice for Single-Line Reefing lmitchell Gear & Maintenance 6 04-12-2007 02:38 PM
single line reefing? jbarros Gear & Maintenance 8 05-16-2003 07:27 PM
