trolling motors - Page 8 - SailNet Community
Advertise Here
Go Back   SailNet Community > On Board > Gear & Maintenance
Like Tree20Likes
Old 01-15-2014
captain jack's Avatar
captain jack is on a distinguished road
Re: trolling motors
Originally Posted by newhaul View Post
If that is the minn kota 3 horse power unit its rated to about 150 lbs thrust however if its the marketing gimmick 3hp for high performance then just around 70 lb thrust
70 is still not bad. how would i know the difference? 150# of thrust would work well for me, according to minnkota's chart. he is contact by phone only. i will have to call him tomorrow. i doubt he'd appreciate a call at 2:35am.
The only rules that really matter are these: what a man can do and what a man can't do.---Captain Jack Sparrow
1971 Cal 27
  #72
Old 01-15-2014
Re: trolling motors
Originally Posted by mitiempo View Post
Certainly not from Minn Kota. Not only do they not publish hp numbers, but as far as I can tell they don't exist. Exaggeration of a salesman perhaps?
apparently not. i saw the pic of the motor. it's clearly labeled 3HP. did they once list HP?
1971 Cal 27
  #73
Old 01-15-2014
mitiempo's Avatar
Re: trolling motors
They could have - but from my searching it isn't true. Post the pic or a link.
Brian
  #74
Old 01-15-2014
Re: trolling motors
http://http://washingtondc.craigslist.org/nva/boa/4281011026.html
1971 Cal 27
  #75
Old 01-15-2014
mitiempo's Avatar
Re: trolling motors
Wonder how old it is? They don't post hp any more, probably because it isn't true. Their largest 12 volt one id 55 lbs thrust currently.
Brian
  #76
Old 01-15-2014
Re: trolling motors
good question.
1971 Cal 27
  #77
Old 01-15-2014
mitiempo's Avatar
Re: trolling motors
Here is a link to Minn Kota's most powerful current outboard. It is listed as 2 hp. Designed to move a pontoon boat or other heavier boat as the primary engine.
E-Drive | Electric Outboard | Trolling Motors | Products | Minn Kota Motors
It is also 48 volts. It sells for about $3200 without batteries.
Brian
  #78
Old 01-15-2014
Re: trolling motors
that being the case, this 3HP is, at least, worth checking out.
1971 Cal 27
  #79
Old 01-15-2014
mitiempo's Avatar
Re: trolling motors
Probably made before honesty in advertising. 12 volts can't do it in a motor that size.
Brian
  #80
Old 01-15-2014
Capt Len is on a distinguished road
Re: trolling motors
I figure you'll have time to sit and figure the money you saved while you buck a bit of head wind .Headway? What headway?
mitiempo and jimgo like this.
You may post attachments
You may edit your posts
Electric Trolling motors opinions yetavon General Discussion (sailing related) 8 07-11-2013 08:07 AM
Back-up motors ambitiousbutrubbish Cruising & Liveaboard Forum 26 09-21-2012 02:41 PM
Used motors santana30RI Gear & Maintenance 15 06-22-2012 08:40 AM
Combining two electric trolling motors a1fa Gear & Maintenance 8 08-18-2011 11:21 PM
electric trolling motors for small sailboats? thebrakes General Discussion (sailing related) 18 07-25-2010 01:29 PM
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
SEO by vBSEO 3.6.1
