VHF/UHF Ham Radio aboard - SailNet Community
post #1 of 3 Old 05-23-2005 Thread Starter
Full-time Cruiser
jonlgauthier's Avatar
There''s lots of info for HF radio aboard a sailboat, but none I can find for ham VHF/UHF (2m/440MHz) while coastal sailing. I was hoping I could find a tri-band mast mount antenna (one that supports Marine (156.025157.425 MHz), amateur 2m (144-148 MHz), and optionally the 430-450 MHz band.
I was hoping to avoid a second antenna, especially one mounted on the rail...
Any ideas?
Jon (KB1HTW)
jonlgauthier is offline
post #2 of 3 Old 05-23-2005
I use the std Marine VHF, it works fine in the 2 Meter Spectrum. So the SWR isn''t perfect, it isn''t on an antena tuned for 2 Meter either unless you are right in the middle. I experimented with both and found the Marine VFH to work fine. You are typically going to a repeater, not the direct distance. An antenna switch and you can avoid the dual antena.
KD4UYN
boatbum is offline
post #3 of 3 Old 08-02-2006
I Feel The 2 Meter Ham Could Be Very Usefull On A Coastal Trip As The Extra Rg. You Get On Xmit Hitting Repeaters 75 Miles Away Gives A Measure Of Safty Over Vhf And Its 30 Mile Rg. Forget Uhf No One Home. I Would Go With The Best 2 Meter Antenna I Could Find And Put It High Same As Tranciever Get The Most Powerful One Could Save Your Life At Least Meet New Friends Along The Way Capt Stu Kb4kph Chesapeake Bay
nhollystu is offline
Life aboard a 24'' sloop? sail1dzn Living Aboard 18 10-02-2016 12:13 AM
Living aboard and learning to sail, or vice versa mark71565 Living Aboard 15 12-31-2008 02:23 AM
Reflections After One Year Living Aboard kmeeks Living Aboard 8 08-26-2006 03:26 PM
HAM and SSB radio reid5009 Living Aboard 1 12-30-2002 04:04 AM
radio communications bullseye Gear & Maintenance 3 08-17-2002 04:09 AM
