Masthead spinnaker bail, could this work? - Page 2 - SailNet Community
post #11 of 13 Old 01-14-2014
Re: Masthead spinnaker bail, could this work?
I would not cut/grind the ears off. You may need them later! Just add a top strap to the crane of sufficient size. to take the Spinnaker halyard block!
mike dryver is offline
post #12 of 13 Old 01-14-2014 Thread Starter
I don't understand, What do you mean by "add a strap"?
Do you mean I go ahead with a (larger 3/8") u-bolt and weld a length of steel to the round end of the u-bolt and screw the other end into the top of the masthead?
Reefpoints is offline
post #13 of 13 Old 01-14-2014
Originally Posted by Reefpoints View Post
It's 316, made by fastenal.
Before the overwhelming consensus to ditch this approach, I was thinking that I may have work-hardened it by bending it or perhaps I should just go 1 size thicker, 3/8" instead of 5/16". It seems that since the masthead has the convenient little "ears" to bolt into, why not use them.
Now, I think I may grind those ears off. That way I could easily fit an upside-down U-channel made of stainless to get a solid 2" or 2.5" of extension.
I you want to increase the distance between the stay and the spinnaker block I would suggest a upside down T or a right side U.
You need to have an attachment point well aft on the masthead if you are going to extend it forward. The ribs on the side of the masthead fitting would interfere with a upside down U.
Here is a picture of my spinnaker crane
Top view
The old spinnaker crane, I don't think it was bent like this when new..
knuterikt is offline
Question of spinnaker bail strength brehm62 General Discussion (sailing related) 3 04-06-2012 12:11 PM
Internal boom bail Barquito Gear & Maintenance 2 08-05-2011 12:17 PM
what is a boom bail? Leland Gear & Maintenance 34 05-29-2008 10:45 PM
Masthead Spinnaker bail attachent coolcarls Newport 1 05-22-2008 09:26 AM
