Wire rope clips vs. nicopress - SailNet Community
 7Likes
post #1 of 16 Old 01-14-2014 Thread Starter
I am replacing my standing rigging this winter. The rigging is from 1977 and is needed as 1 of them has half the wires broken where the wire was kinked at some point of its life before me. I need to do it myself to save cost and because of the setup. Originally they were connected to the mast with a nicopress fitting without a mechanical fitting. I also plan to replace the stainless steel turnbuckles as they are showing some wear. My question is should I buy the nicopress tool and sleeves or use wire rope clips. Seems to me that the only thing the nicopress has going for it is that it is easy, smooth and less likely to snag a sail or clothing passing by it. They also look more likely to fail, being a single connection instead of 3 wire rope clips installed properly. I was also thinking about adding sleeves on the wire rope made from the appropriate size pvc pipe and cap with a hole the size of the rope in the cap so it will slide down over the connections to limit the snag hazard. I think I am going in the right direction but wouldn't mind hearing some pros and cons to the different ways of making secure connections. Please keep in mind that I will be doing this myself regardless of what you say. I am also looking to keep this project as cost effective as possible. The boat is a 26 ft swing keel fractional rig. sailed exclusively on fresh water.
ABH3 Boyer is offline
post #2 of 16 Old 01-14-2014
christian.hess's Avatar
Re: Wire rope clips vs. nicopress
nicopress is fine for boats up to around 32 feet or so
I love them and having a tool for nicopress is great for lifelines making topping lifts or whatever...
people think that only ss rigging is ok when there is nothing further from the tyruth
I also like double ended turnbuckles not studs...as that way if one wire fails or turnbuckles fails and you are on a voyage for example you can rig the good turnbuckle on the failed wire or shroud and then go down below and repair whatever you can with te broken turnbuckle
its also easier to do quick fixes since you just loop an eye and done
for small boats I would go as far as saying that 7/19 stainless wire and all nicopress is absolutely fine and in fact stock
alberg 30s came with nicopressed fittings some years...
you can double up nicopress too if you want it just looks a bit off...but nothing some nice leather wont cover up
jaja
cheers
ps. my wire to rope halyards all use nicopress and Im a 36footer...it was standard for a LOT of boats
ABH3 Boyer likes this.
Merit 25 sold...Islander 36 still afloat? who knows...Im still in Columbus, and back...I think...jajajaja!!!!
christian.hess is offline
post #3 of 16 Old 01-14-2014
mitiempo's Avatar
Nicropress works on a boat the size of yours. Use the correct tool and use 2 sleeves for security. They will hold the full wire strength on 7 x 7 and 7 x 19 wire.
What do you mean by wire rope clips?
christian.hess likes this.
Brian
mitiempo is online now
post #4 of 16 Old 01-14-2014
the mechanical u bolts with 2 nuts I assume...used in galvanized and stainless industrial rigging...and boats too
Im ASSuming
post #5 of 16 Old 01-14-2014
mitiempo's Avatar
Im ASSuming
If that is true he should stick to Nicropress.
Brian
post #6 of 16 Old 01-14-2014
okawbow's Avatar
I rigged my schooner conversion with galvanized wire and nicopress fittings. I bought the tool used, at a great price. I bought a spool of good quality wire rope and found the fittings and eyes online.
On lower fittings, I coated the completed crimp with anhydrous lanoline, and then covered with electrical shrink tubing applied with a heat gun.
The galvanized wire is less expensive, and easy to work with. I haven't seen any corrosion. I have deer stands with galvanized wire supports that have been out in the weather for over 20 years with no rust. An oily rag rubbed over the wire once a year is good maintenance.
Be sure and match the wire strength to the original rigging.
Chuck
Privateer 26 Schooner
okawbow is offline
The Following User Says Thank You to okawbow For This Useful Post:
christian.hess (01-14-2014)
post #7 of 16 Old 01-14-2014
I made a vang with nicopress, using West Marine's crimper (in the store). It failed twice.
So I bought a tool like this :
Nicopress Installation Tool
and doubled up the swages - no more problems.
So I guess I'm just saying, make sure your crimper is good. The results will only be as good as IT is.
MarkSF is offline
post #8 of 16 Old 01-14-2014
yeaaaaaaaaaaaah good crimpers are EXPENSIVE...down here they are way out of my budget...but like most things tool wise...you get what you pay for
ps...I just bought a bolt cutter for my rigging...unless I sharpen the blades and or only use it on rubber...it will not be any use freeing a rig if the mast falls...
post #9 of 16 Old 01-14-2014 Thread Starter
yes wire rope clips are mechanical u bolts with 2 nuts. It just so happens that I already have stainless steel wire rope clips that I acquired at a very low cost from someone who owed me a favor. What I am considering is not using them and using nicopress fittings instead but only if they are much better than what I have. Keep in mind that I will need to go out and buy the tool along with the sleeves. I have been able to locate the 7x19 SS 3/16 wire rope for just under $100 plus shipping for a 200ft roll.
post #10 of 16 Old 01-14-2014
good start...you guys have it made up north...just order online...can do anything you want! jajaja
Wire to Rope Halyards casey1999 Gear & Maintenance 16 05-23-2012 02:52 AM
Changing from wire-rope to all rope hoppy Pearson 5 04-18-2011 03:42 PM
Wire or Rope Luff davejean General Discussion (sailing related) 1 11-08-2003 06:41 AM
Wire-to-Rope Halyards Dan Dickison Gear and Maintenance Articles 0 05-06-2002 08:00 PM
Wire-Rope Halyards Tom Wood Gear and Maintenance Articles 0 08-14-2001 08:00 PM
