DIY Bowsprit - Page 2 - SailNet Community
 2Likes
post #11 of 12 Old 01-16-2014
christian.hess's Avatar
Re: DIY Bowsprit
Originally Posted by sugerpeople View Post
I have been thinking of adding a bowsprit to my J24. Not to use for racing, just for the light air cruising days. I would fly a genaker. Could a retrofit kit damage the bow with unsupported upward forces? Would the tack of the standard 150 genoa chaff on the pole attached to the deck? Is it worth it, or should I just attach the tack of the genaker to the tack of the genny (inside the forestay)?
no prob
just make sure you make a little tack extender(cable and nicopress) to get the tack up and above the bow pit or anything similar that will chafe...
Merit 25 sold...Islander 36 still afloat? who knows...Im still in Columbus, and back...I think...jajajaja!!!!
christian.hess is offline
post #12 of 12 Old 01-21-2014
Re: DIY Bowsprit
I'm assuming that by genaker you are referring to an asymmetric spinnaker.
Asking because some use the term genaker for a code 0 type upwind sail.
Flying a asymmetric on a bowsprit does not put heavy loads on the bowsprit.
The kits from Selden and Sparcraft (and others) have two attachment points to the deck so the loads get distributed.
take a look at this document from Selden http://www.seldenmast.com/files/595-246-E.pdf
That depends on the distance between deck and the tack of the sail.
Normally the bowsprit is located a little off center with the outboard end in the center line.
Tacking a asymmetric sail inside the forestay will make impossible (at least awkward) to gybe..
knuterikt is offline
The Following User Says Thank You to knuterikt For This Useful Post:
sugerpeople (01-23-2014)
Tags
bowsprit , diy , j24
DIY - discussion on building a DIY hookah diving compressor stopher2 Gear & Maintenance 166 2 Weeks Ago 04:09 AM
Retractable Bowsprit DIY Joel H. General Discussion (sailing related) 41 01-15-2013 09:12 AM
bowsprit wood Windkiller Gear & Maintenance 27 11-20-2011 09:41 AM
Bowsprit glegh Sailboat Design and Construction 5 04-13-2009 11:08 AM
bent bowsprit sailhog Gear & Maintenance 7 04-27-2007 08:40 PM
