Wheel to Tiller - SailNet Community
post #1 of 3 Old 06-12-2005 Thread Starter
Wheel to Tiller
I own a 42'' fin keel skeg hung rudder sloop and I would like to get rid of the binnacle shorten my emergency tiller rudder head and put in a tiller. Displacement is 21500 so I go with a 25000 actual disp. Does anyone have experience with doing this and more importantly how do I go about figuring out what the length of the tiller should be?
TADIAS is offline
post #2 of 3 Old 06-12-2005
Moderator
Jeff_H's Avatar
Wheel to Tiller
21,500/ 25,000 is a pretty heavy boat for a tiller, especially if the rudder is skeg hung rather than counter-balanced. In a general sense, if I had to evaluate the length tiller that it would take to replace a wheel steering system and still have similar helm loads, I would work backward from the load on the wheel to calculate the linear force imparted by the drive sprocket into the cables. (The load would be increaded by a ratio of the wheel diameter to the sprocket diameter.) Then I would multiply the force imparted by the cable that you calculated above times the radius of the quadrant to determine the torque in foot lbs at the rudder post. If you divide that torque by the force that you would like on at the grip of the tiller when fully loaded, you would come up with the length of the tiller. In most cases the ratio of tiller length to wheel radius is something like 2.5 to 4 times but you really need to calculate it for the specifics of your boat.
Hoepfully this will be helpful.
Jeff_H is online now
post #3 of 3 Old 06-12-2005
Wheel to Tiller
Well, I''ve converted a wheel to a tiller on a 34'' boat, I own a 37'' boat with a tiller, and have sailed a 42'' boat with a tiller.
I would start with a question as to how much helm do you usually carry, is your boat pretty well balanced to begin with? A tiller will let you know pretty quickly you are carrying too much helm. A short tiller would be a bear to deal with. It can also get pretty tiring after a while. A good tiller pilot like the Ray 4000+ GP should do the trick.
The 42'' boat I sailed (raced) on was a Peterson 42'' IOR Two Tonner known back in the late 70''s as "Love Machine" Her tiller was a wopping eight footer! But she was a breeze to sail in all conditions and a real rocket to weather, with a light helm.
My 37'' is an older circa 1976 IOR Heritage One Ton. She is incredibly well balanced, and will sail with no hand on the stick close reaching in 10 - 15 kts. Her tiller is 5 1/2 feet long (a cool all stainless multi-tube affair as well).
The boat I helped convert was a Peterson 34. We had a nice laminated mahogany stick made up that was about 4 1/2 feet in length. We did have a failure at the fitting we had welded for us at the rudder head. It was aluminium (trying to save weight) and wasn''t strong enough. Went with S/S after that and everything was fine.
I would say that you would want to go as long as you could without running into anything, getting a full unobstructed sweep from rail to rail. Don''t worry about it taking up too much room, you will be able to flip it up out of the way when at rest. While wood is pretty, I like the security of a strong peice of metal. A tapered box section of aluminum, or maybe S/S. Unless you are concerned with weight, stay away from composites and other "Bleeding Edge" materials.
You will want to think about a way to take the strain off the tiller when motoring. the torque your prop wash will put on the tiller will really suprise you. A set of bungies or an easily un-cleated line will go a long way to fighting fatigue if you have to use the iron wind for a prolonged period. (So will the tiller pilot, I might add)
Silmaril is offline
Tiller to wheel conversion costs? 808state Gear & Maintenance 13 06-30-2012 07:11 PM
KISS? or ... why a wheel? jbarros General Discussion (sailing related) 48 12-15-2008 04:17 PM
Aquarius 23 wheel steer back to tiller woodyr Gear & Maintenance 0 06-24-2004 08:13 PM
What Would You Buy For 70 Grand Dav-O Boat Review and Purchase Forum 22 03-26-2002 09:11 PM
retrofit, tiller --> wheel ryba General Discussion (sailing related) 5 10-18-2000 03:14 PM
