Repairing inflatables - SailNet Community
Blogs
Old 06-19-2005
sneuman is on a distinguished road
I''d be interested in hearing from anyone who has repaired a slow leak in a zodiac-type inflatable dinghy.
Old 06-19-2005
gunnyman is on a distinguished road
Have repaired a few. What are your questions. I''ll be glad to help if I can.
Old 06-20-2005
Well, it''s a very slow leak, so not even sure I can properly identify it with soap bubbles. So, that''s the first problem. And ... what did you use to make the repair? Did it hold?
Old 06-20-2005
dman is on a distinguished road
This was recently covered ,you should try the search.If it doesn`t make a bubble then it isn`t leaking.
Old 06-20-2005
FalconEddie is on a distinguished road
I just went through this whole process and discovered a couple of basic facts of life concerning RIB repair.
1.) There is no ''quick and easy'' way.
2.) Get the boat out of the water and prepare for a serious repair.
3.) Get the CORRECT repair supplies, including new, fresh adhesive.
4.) Don''t avoid the $40 adhesive because of cost - it works best.
5.) Download the instructions found on line and follow them religiously.
I used a thick mixture of Dawn and water and slowly went around the boat applying it and finally found the tiny leak. (It was taking my boat a week to go soft and no amount of Viagra helped)
I took other peoples (around the marina) well-meaning advise and the leak re-appeared every two weeks. I was also occasionally dealing with a sometimes leaky fill valve.
Frustrated, I finally got the right materials and waited for the right (temp/humidity) day, did the repair, and it has been rock solid for three months now.
No short cuts. Research on line for your exact material (my boat is a Hypalon Avon) and get the right stuff and the right directions. Use Toluene for cleaning the surface instead of MEK. It smokes your liver a tad but does a better job. Hold your breath while using it.
Old 06-20-2005
sneuman, FalconEddie hit it on the head.Follow his advise , especially about the adhesive.
Old 06-21-2005
goduke is on a distinguished road
Also - have a marking pen like a Sharpie with you when you''re looking for the leak so you can mark it immediately without having to stop - find a pen and loose the spot
Old 06-21-2005
pjfsail is on a distinguished road
dman, suggested, "This was recently covered ,you should try the search.If it doesn`t make a bubble then it isn`t leaking. " I have tried to search using the following: "leaking inflatables", "leak", "inflatables", "how to fix a leak in an inflatable". I come up with nothing, zero, zilch. I HAVE a leak in my inflatable. I can''t find it. It does NOT make any bubbles. It DOES leak as I have to fill the front compartment every week. DON''T tell me it''s NOT leaking. It IS leaking. So what ARE the key words to the search? Thanks, Peter
Old 06-22-2005
I have also had trouble with the search function
Old 06-22-2005
pjfsail If it doesn`t make a bubble it is not leaking.Since your inflatable is leaking the soap/water cannot be over the leak,it is that simple.The slightest leak will be detected.No bubbles no air loss,so be more carefull in your attempt.Well the good news is that it will only leak more if you can`t find it.lol
repairing keel - fiberglass cut trecksail Gear & Maintenance 13 02-17-2005 03:03 PM
Sea Eagle inflatables ricekrgr General Discussion (sailing related) 1 10-17-2003 03:06 PM
Repairing core moisture ughmo2000 Gear & Maintenance 7 10-01-2003 08:19 PM
inflatables NukaHiva Gear & Maintenance 6 07-05-2002 06:07 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
