Old 06-19-2005
HuntersMoon22 is on a distinguished road
Outboard won''''t stay in neutral
We have a 7.5 Johnson outboard on our Hunter 22. Since we launched in early June and reversed off low-loader, when the gear is put into neutral the propellor still turns slowly which is a bit nerve wracking!
We''ve tried "clicking" it into neutral by manually turning the prop while on the mooring, but no luck.
Just wondered if anyone had any tips on what we could try, other than take it to a mechanic. It''s a Johnson with the long shaft and weighs about 75 lbs, so we''d just as soon try out some tips before getting it to a mechanic!
Thanks!
You may post attachments
You may edit your posts
Outboard motor controls waltzingmatilda Gear & Maintenance 3 05-05-2010 09:08 AM
Symphonie Baby Stay billhercus Racing 9 04-03-2009 12:10 AM
Outboard: Buying, Type & Fitting omega001 Gear & Maintenance 11 11-10-2006 10:09 AM
Transmission Engages while in neutral...? kmeeks Gear & Maintenance 1 02-18-2004 09:56 AM
Charleston boat stay wanted SailinCowboy Living Aboard 2 11-07-2002 01:23 PM
SEO by vBSEO 3.6.1
