Old 06-27-2005
rbtpfe9 is on a distinguished road
Sta Lok system
I need to do some work on rigging and was curious if anyone has had experience with Sta Lok systems. I need to replace jib halyard and am looking at possibly changing from swage terminals. Thanks
Old 07-19-2005
mary jewell is on a distinguished road
Sta Lok system
I recently replaced all of my rigging with the sta loc system....very easily done...what specifically do you need to know about?
Old 07-20-2005
Sta Lok system
I was curious if anyone had experience any failure or other complications. I''ve read all the pr and understand Lloyds loves them, etc. but actual experience helps my "comfort."
Old 11-14-2009
Ulchute is on a distinguished road
Dear Folks:
I'm doing a re-rig project on a Venture '26. I'm planning to use 3/16", 1x19 stainless wire rope but was looking for advice on terminals. Sta-loks look like they might be easy to work with but I'm a newbie. Any advice would be most appreciated.
Thanks,
Old 11-14-2009
imagine2frolic's Avatar
imagine2frolic is on a distinguished road
If you can handle taking off a tire during a flat. Then you can handle sta-lok.......i2f
20 MPH ain't fast unless, you do it in a 1000sq 3/2 house on 10foot waves
BORROWED, No single one of us is as smart as all of us!
Old 11-14-2009
scottyt is on a distinguished road
i have a single sta lock on my boat, the starboard shroud bottom. when it comes time to rerig it will get swages at the top and stay locks on the bottom. just order the cables with swages at the top and a little long then you can cut to fit. turns the rigging to a diy job, and you can order the cables from where ever that is cheap ( but good ) by mail
Old 11-14-2009
captbillc's Avatar
ancient mariner
captbillc is on a distinguished road
i replaced the headstay on my boat a couple of years ago using a swaged terminal on the top & a staylock stud terminal on the bottom. had to take the harkin roller furling apart to install the stay. it was the first one i had done. i read the harkin manual & staylock instructions, and followed them exactly. it worked out well.
Liberals are people who care about others. Freethinkers are not constrained by the myths of religion.
Old 11-14-2009
mitiempo's Avatar
When I re-do my entire rig in the spring I will also get the wire cut a bit long and with swages for the top end. Not sure for the bottom end but it will be either Sta-Lok or a similar fitting. The Hi-Mod fittings from Hayn Marine are interesting and probably deserve a look at but in a re-rig I would not use swages for the bottom end under any circumstances. You can't see what's happening in them and corrosion is an issue.
Brian
Old 11-15-2009
mintcakekeith is on a distinguished road
I use swages at top, staylocks at bottom also.read instructions and fill staylock with recomended compound and jobs a good un k
Old 11-15-2009
I would second what mintcakekeith said. Using swages at the top and mechanical fittings at the bottom will save you some money and make things a good deal simpler. I'd also point out that of the mechanical rigging fittings, Hayn Hi-Mods are considerably less expensive and better quality IMHO than the StaLocks. Sailboat hardware, rigging and standing rigging from Rigging Only is an excellent source.
Control Head fix for Merriman Steering System tdp Gear & Maintenance 1 06-09-2011 03:00 PM
Salt Water Cooling System failure. rclampitt Gear & Maintenance 4 07-28-2002 09:26 PM
WEST SYSTEM Boys Bilge_Scum General Discussion (sailing related) 0 07-07-2001 04:30 AM
Spartite 2000 mast wedge replacement system - need info Capt.CarroleWard Gear & Maintenance 2 05-30-2001 06:01 PM
Isomat Reefing System sailbouy Gear & Maintenance 1 03-12-2001 04:38 PM
