Diesel fuel filter - SailNet Community
post #1 of 2 Old 06-28-2005 Thread Starter
Diesel fuel filter
I have located a Racor-like diesel filter/water separator (with vaccum guage, inspection pan, etc.) used on small (i.e., non-marine) diesels here in Thailand. The cost, not to mention the lack of shipping, will make this significantly less pricey than ordering a Racor from West Marine or other supplier. Assuming it''s a 2 micron filter (something I need to double-check), is there any reason it couldn''t be used? Another advantage may be replacement filters for this unit more available here. Pre-emptively, I know there will be some here who will want to say "if it''s not marine grade, don''t use it." I respect that, but would like some evidence that "marine grade" is really anything more than a reason to jack up the price in this case. Many thanks your thoughts.
sneuman is offline
post #2 of 2 Old 06-29-2005
Diesel fuel filter
i would use it. what have you got to lose?
worst case the housing of the filter might rust. otherwise a filter is a filter.
fair winds,
eric
Amel SM kimberlite
kimberlt is offline
fuel consumption gas vs diesel jklewissf Gear & Maintenance 25 05-11-2013 08:28 PM
Diesel fuel RSchneider Gear & Maintenance 4 10-19-2009 10:39 AM
fuel filter changes stm Gear & Maintenance 3 01-27-2003 01:41 PM
is diesel fuel compatible with lined tank? johnbonner31 Gear & Maintenance 1 12-27-2002 03:10 AM
diesel fuel filter tho52mas Gear & Maintenance 2 05-16-2002 11:26 PM
