Standard Horizon CP160 - SailNet Community
post #1 of 2 Old 07-04-2005 Thread Starter
I am having a problem with my CP160 Chart Plotter. For some reason when it''s in active tracking chart mode, the position it has me at on the chart is different from my actual position. Sometimes itís off up to 80-100 yards. I can only assume that it needs to be re-calibrated or some parameter has been changed. There is no manual correction entered and the error changes depending on COG? Does anyone have any ideas or where to start looking? The CP160 has been discontinued by S-H
Mike T
E-29
mikes-zephyr is offline
post #2 of 2 Old 07-04-2005
catamount's Avatar
I don''t know anything about the CP160, but the error you describe could be due to a mismatch of datums between the chart and your GPS position. Check what datum the chart was produced with (could it be the older NAD27?), and check the datum setting for your GPS receiver (typical default setting is WGS84).
See http://www.sailnet.com/collections/articles/index.cfm?articleid=sexton046 for one discussion of datum.
Regards,
Tim
catamount is offline
Standard Horizon Wind Instruments branda Gear & Maintenance 5 07-09-2015 07:02 PM
New Horizon 26-sorry about second header Jeff_H Gear & Maintenance 4 06-12-2011 10:39 PM
Inquiry about Horizon Yacht Charters BVI sailthechesapke Chartering 4 04-27-2009 12:57 AM
Standard Survey Format? Bilge_Scum Boat Review and Purchase Forum 1 09-18-2001 05:25 AM
GPS III vs Standard H 150 chartplotter sanuk Gear & Maintenance 1 03-21-2001 09:44 AM
