How do I keep travelift slings from topsides - Page 2 - SailNet Community
 2Likes
post #11 of 24 Old 01-22-2014
"Anhinga" St. Augustine
Capt.Alex's Avatar
Re: How do I keep travelift slings from topsides
I have seen yards use clear plastic sheeting. They sleeve the travelift straps with it. The straps can then stretch and slip inside the plastic sleeve which stays stationary against the hull.
Capt.Alex is offline
The Following User Says Thank You to Capt.Alex For This Useful Post:
WhitingSailor (01-22-2014)
post #12 of 24 Old 01-22-2014
Originally Posted by WhitingSailor View Post
We have just had our yacht vinyl wrapped
Question, did you wrap the boat as an alternative to paint?
How long do you expect the covering to last?
knuterikt is offline
post #13 of 24 Old 01-22-2014 Thread Starter
Yes, the wrap is an alternative to a paint job and also as a means to protect the underlying gel coat. It has been used for some time in the UK and is now becoming more common here in New Zealand. 3M give a 7 year warranty and the expected lifespan is up to over 10 years obviously depending on how you treat it. It is applied on the hardstand without having to go into a shed and our 47 foot boat was done in a day complete with name graphics. Cost about 30% of a paint job so can be done a number of times for the cost of one paint job. Hopefully we will get what the promises state. It can be removed if you want to change. Cheers
Have a look at www.wildgroupinternational.com or www.vinylboatwrap.co.nz
Whiting 47 - "Mystery Girl"
"The horizon is just the beginning"
WhitingSailor is offline
post #14 of 24 Old 01-22-2014 Thread Starter
Thanks, sounds like a solution that the yard should implement. I will discuss with them.
post #15 of 24 Old 01-22-2014 Thread Starter
Originally Posted by Yorksailor View Post
Use your wife's best pillows!
Sounds like a plan....do you know a good divorce lawyer!!!!!!!
post #16 of 24 Old 01-22-2014 Thread Starter
Originally Posted by svHyLyte View Post
Wouldn't it be easier to have the boat wrapped once it's out of the water?
The boat is wrapped out of the water...it is a coating that is an alternative to painting the hull...see my post down a few for links to sites about this. Cheers
post #17 of 24 Old 01-22-2014 Thread Starter
Originally Posted by zz4gta View Post
???? the yard doesn't have something to put inbetween the hull and the straps? Places on the ches bay use carpet or foam as a buffer.
They did put some form of wax paper on but it obviously didnt do the job. Cheers
post #18 of 24 Old 01-22-2014 Thread Starter
Originally Posted by three-quartertime View Post
Ditto on Chesapeake marinas using pads. I've had my boat hauled out at three different marinas. While wasn't SOP, when I pointed out that the hull is awl gripped, all three used pads between the hull and slings. One marina even used clean cotton towels in addition to pads. If you haven't already talked to your marina, give it a shot. They might have a way of dealing with painted top sides that would also solve your particular problem.
Thanks for the comment. I will talk with the marina. Any idea what the pads were made of? Cheers
post #19 of 24 Old 01-22-2014
Old as Dirt!
svHyLyte's Avatar
Ah... Now I understand. Sorry for the confusion. (It's winter here and lots of folks have their boats "wrapped" for winter storage.)
N'any case, good luck. Thick pads of tufted carpet liberally sprayed with SailKote or another similar dry lubricant might do the trick.
svHyLyte is offline
post #20 of 24 Old 01-22-2014 Thread Starter
Thanks. I am getting lots of good advice to discuss with the yard. Fortunately here we dont have snow or severe winters and can sail all year round so dont have boats wrapped for storage. Cheers
Tags
fenders , haulout , travelift
Blue topsides Barquito Gear & Maintenance 26 03-12-2012 03:53 PM
Life-Slings and what I didn't know... artbyjody Seamanship & Navigation 15 01-12-2008 09:35 PM
Looking for Topsides Painter NewsReader Mass Bay Sailors 0 06-11-2007 11:15 AM
topsides paint JimOppy Gear & Maintenance 2 11-10-2003 02:06 AM
Imron on Topsides? Andy S Gear & Maintenance 2 10-23-2002 08:21 AM
