Mainsheet system - Page 2 - SailNet Community
 1Likes
post #11 of 25 Old 01-22-2014
Re: Mainsheet system
Anything more than 6:1 is really too much spaghetti in the cockpit. Try a Google search on something like 'mainsheet fine tune' and you might get some more ideas. I did it on my boat, a First 375 (and I needed it too)
sandy stone is offline
post #12 of 25 Old 01-23-2014 Thread Starter
Originally Posted by olson34 View Post
You might want to talk to the tech guys at Harken. Over a decade ago they worked with a local yard to develop a gross/fine system for a friend of mine with an Ericson 33 (the Ron Holland design with the fractional rig and monster mainsail).
It's a 5 to 1 / 10 to 1, using stacked fiddle blocks, double-ended sheeting. Pull either one for the 10 to 1, or pull both together for the speedier 5 to 1.
Works wonderfully.
I have crewed on the boat off n on for 15 years.
My own boat has a smaller main and gets by fine with a 6 to 1 system.
As someone once observed-- it's all just Choices and Options. But, the more purchase you have, the easier it is to really enjoy sailing the boat when the pressure goes up.
Cheers,
Loren
Interesting system, 10:1 fine, 5;1 coarse but there was still line in the cockpit for the 10:1 purchase, yes?
John
jfdubu is offline
post #13 of 25 Old 01-23-2014 Thread Starter
Sandy, this is my point. I'd guess that 6:1 alone wasn't enough for your 37.5 so you had a fine leg on the end. 8:1 isn't difficult or that expensive to rig but I'm looking at about 120' of line. I could do a 6:1 with a 3:1 fine without too much trouble. The only wildcard there is teaching the crew when to use the fine and coarse adjustments.
John
jfdubu is offline
post #14 of 25 Old 01-23-2014
RichH's Avatar
Here's the Harken Manual on "Cascading" and "Gross/Fine" mainsheet handling systems: Harken
IMO - For a mainsail of your size and with end-boom sheeting typically such large 'power ratio' systems are unneeded, even without using 'winch assist'. Your 'end boom' sheeting provides a LOT of mechanical advantage all by itself. I myself raced a P30 (200 sq. ft. main) with end boom sheeting with a 4:1 mechanical advantage for many years and seldom needed 'more power' when pulling this system entirely by hand even when apply gorilla strain to the mainsheet, of course all the mainsheet system blocks were all roller bearing blocks.
RichH is offline
post #15 of 25 Old 01-23-2014
I set up fine tunes on pretty much every boat I sail. I would run a 6:1 with a 12:1 fine tune on your boat, but with a very short throw on the fine tune. This gets the excess line out of the cockpit.
In order to do this instead of dead ending the line on the becket, add a simple block. On the other end attach a small block w/ becket and cam. I away from the boat right now so I can't get a picture, but it's pretty commonly done. It only gives you a few feet of fine tune, but that's all you generally need.
Greg
Stumble is offline
post #16 of 25 Old 01-23-2014
John
Yup. The boat seems to have enough main sheet length that we've never run short. After a hard windy sail, when we come in to the dock, sometimes we run the tails back on one side until they are equal again.
Loren
olson34 is offline
post #17 of 25 Old 01-23-2014
blt2ski's Avatar
I have a 4-1 with another 4-1 on the back leg, giving me 16-1 for fine tune. I also have enough line on the micro 4-1 to douse the main when really windy, and pull it back in. Pretty nice when I only have a 195 sq ft. I would do the same with the OP's setup, but probably a 6-1 macro with a 6-1 micro, giving me 36-1 overall!
HEre is a picture.
Marty
She drives me boat,
I drives me dinghy!
blt2ski is offline
post #18 of 25 Old 01-24-2014
I don't discuss my member
zz4gta's Avatar
Originally Posted by blt2ski View Post
This is exactly what you want. You could do a simple 6:1 and add a couple blocks to make a 12:1 and it would be perfect.
Merit 25 # 764 "Audrey"
zz4gta is offline
post #19 of 25 Old 01-26-2014 Thread Starter
I'm going to end up with some variant of a 6:1 coarse with a fine adjustment. I post pics when I finish the design.
John
jfdubu is offline
post #20 of 25 Old 01-26-2014
Don't underestimate the importance of the type of rope you're gonna use in such a system...
In my opinion, the choice of a single braid like NER's Salsa, or Yale's PHD makes a huge difference in how well these cascades will run, and general ease of handling...
Ph.D Racer Rope | Custom Racing Rope | Yale Cordage | Yale Cordage
JonEisberg is offline
Pearson 27 Mainsheet system davidpm General Discussion (sailing related) 11 02-18-2013 03:19 PM
28II Mainsheet system stpabr Newport 5 03-26-2011 12:08 AM
mainsheet system for daysailer dogfuel General Discussion (sailing related) 3 11-29-2010 07:12 PM
Pros and cons of split mainsheet system zAr Seamanship & Navigation 9 06-06-2009 10:12 PM
Mainsheet System tdw General Discussion (sailing related) 31 11-09-2008 05:36 AM
