Mainsheet system - SailNet Community
 1Likes
post #1 of 25 Old 01-22-2014 Thread Starter
Mainsheet system
Topic for opinion, The new (to me) boat I purchased in the fall has a 6:1 mainsheet system. It's end boom sheeted with 293 sqft of mainsail. The current blocks are wore out and I've already decided to replace them.
So the question, 8:1 vs 6:1?, does anybody use an 8:1 system for their main sheet? When I run the numbers at 20knot of breeze only a gorilla would be able to sheet the main at 6:1 but I suppose I should be reefed by then. 8:1 would easier to control and adjust under normal conditions but I end up with 100' of line in the cockpit.
Thoughts/opinions, please.
John
BTW, the boat is a Goman Express 35
jfdubu is offline
post #2 of 25 Old 01-22-2014
ASA and PSIA Instructor
Re: Mainsheet system
No winch in the system?
Regardless, for the replacement blocks, get Garhauer.
sailingfool is offline
post #3 of 25 Old 01-22-2014
Does the gorilla get to use the winch ?
fred1diver likes this.
"Just call me TB"
capttb is offline
post #4 of 25 Old 01-22-2014
Yorksailor's Avatar
We have a Garhauer 6-1 on a 700 sq ft main and no winch. And I am 65 yrs old!
Yorksailor is offline
post #5 of 25 Old 01-22-2014
deltaten's Avatar
Send a message via Yahoo to deltaten
a comparison......
my 150 s/f something, 10+ ft boom uses a 4:1 and needs only 75' of line to reach (near) 90 degrees. You *gotta* need more at 8:1 and a bigger boat!
6:1 is prolly fine; perhaps using well-bearing'd blocks to reduce friction as much as possible? Remember.... an end-boom fixture is at the end of a longish lever with most of the load in the center and fwd,
S/V Chrysalis
'80 Watkins 27
North East, MD
deltaten is offline
post #6 of 25 Old 01-22-2014
John
A two speed system like this could be a solution
This is Garhaure but you can find this from other makes also
knuterikt is online now
The Following User Says Thank You to knuterikt For This Useful Post:
Classic30 (02-16-2014)
post #7 of 25 Old 01-22-2014 Thread Starter
This is the system I have but by lemar. completely wore out. It.s a 6:1 single or 3:1 double.
John
jfdubu is offline
post #8 of 25 Old 01-22-2014 Thread Starter
York, that's pretty amazing. Using the mainsail load calculator on the harken site a 600 sqft sail loads 2044 lbs in a 20 knot breeze. With a 6:1 your trimming 340 lbs?. Drop the wind to 12 knot and it's still 122 lbs.
I guess I need to grind the numbers myself.
John
jfdubu is offline
post #9 of 25 Old 01-22-2014
deltaten's Avatar
total sail load,s a ton, but one end...smaller at that , will carry (less than ) half. not an NA, nor an kinda injunear, but it sure would seem the load would be mostly on mast. then the rest is dealt with by the "lever"/boom
S/V Chrysalis
'80 Watkins 27
North East, MD
deltaten is offline
post #10 of 25 Old 01-22-2014
Lightbulb Re: Mainsheet system
You might want to talk to the tech guys at Harken. Over a decade ago they worked with a local yard to develop a gross/fine system for a friend of mine with an Ericson 33 (the Ron Holland design with the fractional rig and monster mainsail).
It's a 5 to 1 / 10 to 1, using stacked fiddle blocks, double-ended sheeting. Pull either one for the 10 to 1, or pull both together for the speedier 5 to 1.
Works wonderfully.
I have crewed on the boat off n on for 15 years.
My own boat has a smaller main and gets by fine with a 6 to 1 system.
As someone once observed-- it's all just Choices and Options. But, the more purchase you have, the easier it is to really enjoy sailing the boat when the pressure goes up.
Cheers,
Loren
olson34 is online now
Pearson 27 Mainsheet system davidpm General Discussion (sailing related) 11 02-18-2013 04:19 PM
28II Mainsheet system stpabr Newport 5 03-26-2011 01:08 AM
mainsheet system for daysailer dogfuel General Discussion (sailing related) 3 11-29-2010 08:12 PM
Pros and cons of split mainsheet system zAr Seamanship & Navigation 9 06-06-2009 11:12 PM
Mainsheet System tdw General Discussion (sailing related) 31 11-09-2008 06:36 AM
