Last but not least, I need an anchor - SailNet Community
 6Likes
post #1 of 26 Old 01-22-2014 Thread Starter
first sailed january 2008
northoceanbeach's Avatar
Sorry to bombard the g and m section, but I just got a new boat and I'm trying to budget and prioritise everything it did not come with.
It is 5500# fin keel. As of now it has no windlass.
Last year I hand pulled a 22 lb Bruce claw with 25 ft of chain. That was on a 3500# boat and it never failed me. It was one size up.
For some reason these boats just don't seem to come with anchors. Well I take that back. They come with all the danforth knockoffs you could ever want. Ive started a collection in my garage.
But I need a real anchor. Preferably one a size up aka the storm size. I was happy with the claw, would t mind other options. I have heard the new designs are great but don't know anything about them.
At 5500# am I still good with say 25-30 feet of chain and rope combo? It has the standard anchor locker right at the front of the bow. I dont know anything about installing a windless. I assume they make hand crank ones also. To install a windlass do you have to cut a hole in the deck or do they bolt through?
What system would you recommend? I'm finding someone's advice very good when earlier I had mentioned my budget for a boat was x. He said my budget was really y because it would cost $5000 to get it set up. At the time I was thinking "pss I'll just find one that comes with everything" when I looked at this boat I thought wow, this has everything(except a dinghy). That was wrong.
As an aside. Whenever I see those shiny anchor they seem to be permanently attached to the chain. There isn't an Allen wrench bolt or anything. What is this? An anti theft measure is all I can think of but I can't think of anyone stealing an anchor.
northoceanbeach is offline
post #2 of 26 Old 01-22-2014
islander bahama 24
newhaul's Avatar
Re: Last but not least, I need an anchor
Be glad to take a couple of those Danforth anchors off your hands any in the upper twenty lb range I need a spare or two if price is right
Illegitimus Non Tatum Carborundum.
newhaul is offline
post #3 of 26 Old 01-22-2014
what type of boat?
barefootnavigator is offline
post #4 of 26 Old 01-22-2014
JimsCAL's Avatar
Don't think you need a windlass on a boat that size. I don't have one on my 11,000 lb 33 footer. And 25-30 feet of chain plus nylon rode sound good to me. Since you are buying new, I would go with a Manson Supreme or Rocna as your primary. Use one of the Danforths as the secondary.
JimsCAL is offline
post #5 of 26 Old 01-22-2014
Mantus. Hands down.
It's what's on my bow.
And they have exceptional customer service.
Dfok likes this.
smackdaddy is offline
post #6 of 26 Old 01-22-2014
no longer reading SailNet
Alex W's Avatar
I really like my modern-gen Manson Supreme. The Seattle boat show starts on Friday and last year I got the 25lb Manson Supreme at Fisheries using a boat-show deal for about $150. Normal price is about $100 more (or $300 at West Marine).
My neighbor has an bruce anchor just like the one that you bought from us last year that he'd sell. The 22lb size is still plenty big for your new boat.
Alex W is offline
post #7 of 26 Old 01-22-2014
blt2ski's Avatar
For how I use my 6500 lb boat here in the salish sea, a 9 lb fastset with a whopping 6' of 3/8" chain is my always up front ready to deploy race anchor. Holds me well too, even up to 15 knot winds. I seem to recall seeing somewhere a max of 20 knots for a boat my size.
My other anchor is a true bruce at 7.5KG/16.5 lbs and 20' of 1/4 chain. Came with the boat, has held me fine into the mid 20's steady, gusts into the low 30's. If I was going to be anchoring a lot, 40-50' of 5.16" chain would be prefered, along with an anchor in the 10-12KG, or mid 20 lb range for around here.
You can decide on the style other than a plow/spade style would be my choice as I already have.
marty
She drives me boat,
I drives me dinghy!
blt2ski is offline
post #8 of 26 Old 01-23-2014
I use a bruce with about the same amount of chain you mentioned. I also sail in the PNW and it has never failed me either. Since they have no moving parts and are considered an "older" anchor a good used one could be a real bargin for a safe anchor. My boat is 30, about 9,000 and I do not have a windlass. The only time I wish I had one was last summer in the San Juans when it was blowing hard and I could not pull the boat up to the anchor and had to motor up on it. If I had been single handed a windlas would have been nice to help handle the rode (you are not supposed to use a windlas to drag the boat around). As it was I had my wife at the helm so got it up without too much trouble.
baboon is offline
post #9 of 26 Old 01-23-2014
Here's what I have for the PNW used the "complete book of anchoring to get the wind strain and holding numbers:
Working Anchor (to 30 kts) Bruce-sand, mud, gravel
Storm Anchor (to 45 kts) Fortress -sand, mud
Stern Anchor Danforth-sand, mud
Back-up anchor Northill- gravel, rock, weed
Tandem Anchors (to 80 kts. or surging)Fortress/Danforth-sand, mud
Here I think it's handy to have more than one type because of different bottoms. A killet is handy if you need to use a short scope e.g. crowded anchorage also helps to keep the rode from getting run over. The rule of thumb for chain has been the boat length. When I did the numbers I found that my two bolt cleat was under strength so I put in a four bolt in the deck with a big backing plate. I also split the anchor's chain locker in half and put in another cowl. So I have two anchors on the bow, Bruce and Fortress each with its own rode. I can also hook the two rodes end to end if I need an extra long one. An inexpensive place to anchor shop is the consignment stores
Walt Elliott
Kingston WA
Puget Sound
Cal-29
Waltthesalt is offline
post #10 of 26 Old 01-23-2014 Thread Starter
I think I may be going the 22 lb Bruce route. It served me without fail in over 120 situations last year.
Where to anchor? Sageman Living Aboard 2 05-23-2013 03:59 PM
To anchor box or not to anchor box?? hmm Windkiller Gear & Maintenance 14 05-01-2012 03:19 PM
Anchor alarm for android phones - Anchor Alert Bene505 Electronics 28 04-29-2011 06:31 PM
Yet another anchor question. Has anyone seen/used an Oceane anchor? SVDistantStar Gear & Maintenance 2 08-28-2008 02:09 AM
The Second Anchor Tom Wood Seamanship Articles 0 07-06-2004 09:00 PM
