Water hoses gooey - SailNet Community
post #1 of 9 Old 01-24-2014 Thread Starter
Dave_E's Avatar
Water hoses gooey
Hi All,
Life long mechanic, but I've got one here I've never seen. As I was going through the Universal 5424, I replaced a water hose, (from the engine to the boat heater). No big, bought the hose at the local auto parts store. Installed it 2 months ago, everything has been fine. I was In the engine this past weekend just looking things over and I brushed against this hose. Just this hose is shiny and if you wipe a rag over it, it's all gummy and it comes off on the rag. Ideas?
Dave
Allmand Sail 31 #15 "Traveler"
GOD, Family, career
Dave_E is offline
post #2 of 9 Old 01-24-2014
Re: Water hoses gooey
Sounds like the hose was uncured or otherwise defective material. Brand name or bargain bin? In any case, I'd replace it ASAP. Take it back to the store & let them see the problem, while you're at it.
hellosailor is offline
post #3 of 9 Old 01-24-2014
Sailor
Gladrags1's Avatar
Engine overheat? Assuming you bought a coolant or heater hose for a vehicle it should be ok with the temps that the diesel gets normally. That's a puzzle for me as well!
Sent from my iPhone using Tapatalk
Mandolin
Bayfield 36
Sailing out of Rock Creek, Chesapeake Bay
Gladrags1 is offline
post #4 of 9 Old 01-24-2014
Learning the HARD way...
eherlihy's Avatar
something (coolant, fuel, engine cleaner, etc.) is acting as a solvent, and attacking the hose. Replace the hose with another brand and chemical makeup.
Sent from my VS930 4G using Forum Fiend v1.1.3.
eherlihy is online now
post #5 of 9 Old 01-24-2014
RichH's Avatar
Probably an overdose of 'molding aid' compound added to the 'rubber' when extruding/forming it and now the 'molding aid' is migrating to the surface of the rubber.
Same thing happens to extruded/molded vinyl (electric cords and boat fenders) ... eventually over a long time forms a sticky goo on surface. That your water hose shows the goo very quickly - compounding error with too much molding aid. That hose was probably the first to be made on a monday morning, ... after a long weekend.
Most of these molding aid compounds are slightly soluble in oil.
RichH is offline
post #6 of 9 Old 01-24-2014 Thread Starter
Dave_E's Avatar
Thanks for the replies. No engine overheat issues. I'll go along with bad hose and replace it.
GOD, Family, career
Dave_E is offline
post #7 of 9 Old 01-24-2014
pdqaltair's Avatar
It may be oil causing the damage. I started a recall for major a bus manufactur when I noticed they were using a EPDM coolant hose under the dip stick (oil disolves EPDM). It was a Gates coolant hose, very low in permiability, but unsuitable for use around oil or diesel.
It is much less likely to be a coolant or curing issue than a wrong material issue (I work in the industry).
https://www.gates.com/downloads/file...hemical_04.pdf
http://www.gates.com/brochure.cfm?br...ocation_id=541
AVOID EPDM Hoses!!
Writing full-time since 2014
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is offline
post #8 of 9 Old 01-24-2014 Thread Starter
Dave_E's Avatar
[QUOTE=pdqaltair;1339521]It may be oil causing the damage. I started a recall for major a bus manufactur when I noticed they were using a EPDM coolant hose under the dip stick (oil disolves EPDM). It was a Gates coolant hose, very low in permiability, but unsuitable for use around oil or diesel.
The hose runs above the engine over to the side of the dog house and down. I don't have 1 drop of stray oil in the compartment. I am going to go to the marine store for a replacement. Thanks.
GOD, Family, career
Dave_E is offline
post #9 of 9 Old 01-24-2014
pdqaltair's Avatar
[quote=Dave_E;1340681]
Just a bad batch, then.
Incoming water hoses univeral 5411? dickauge Diesel 5 07-19-2013 09:16 AM
Gooey / sticky issue mdbee Gear & Maintenance 2 10-27-2010 05:49 PM
New Fuel Hoses jlb40514 Pacific Seacraft 4 01-23-2010 08:38 AM
hoses johnharch Pacific Seacraft 3 11-14-2009 09:36 PM
Exhaust Hoses thisisus Gear & Maintenance 3 08-09-2009 06:42 AM
