07-25-2005
jib view window
A vinyl window installed as a retrofit is usually an easy job for a sailmaker. Things to avoid: placing the window near the edges of the sail or near any seams. If the window must go through a seam consider two windows - leaving the original seam.
One downside with furling headsails and vinyl windows: the moisture from a wet rolled/furled sail will turn the vinyl ''milky''; but, this will dissappear when the vinyl ''dries out'' and the absorbed water exits the vinyl.
Go for it, better than raising the sail up from the deck .... and losing all the ''end-plate'' effect of a ''deck sweeper'' that makes a genoa sooooo efficient.
