How to rig a Sta-lok terminal - SailNet Community
 4Likes
  • 1 Post By Rhapsody-NS27
  • 1 Post By Delezynski
  • 2 Post By zz4gta
post #1 of 9 Old 01-25-2014 Thread Starter
billyruffn's Avatar
Drake on Paragon has a new video out showing how to rig a Sta-lok terminal. Have a look.
http://m.youtube.com/watch?v=Vo_H1qm...em-subs_digest
billyruffn is offline
post #2 of 9 Old 01-26-2014 Thread Starter
billyruffn's Avatar
Re: How to rig a Sta-lok terminal
Found part 1 of the above video. It also has very useful tips form Drake's rigger.
post #3 of 9 Old 01-26-2014
Well, good thing those fittings were Norseman, and not Sta-Loks, because he forgot to put in the 'formers' that are a part of the assembly of the latter :-)
One offhanded comment from the rigger surprised me, however... He pointed to a bit of surface corrosion/light rust on the re-used fitting, and suggested something to the effect that "you could clean that up or remove it if you feel like it, but it doesn't really matter..." Maybe just me, but I would think a professional rigger would suggest one deal with even the slightest hint of surface corrosion whenever it appears. Chances are that fitting is going up to a tang on the mast, after all, where it will be 'out of sight, out of mind', for the most part...
JonEisberg is offline
post #4 of 9 Old 01-26-2014
Chastened
Ajax_MD's Avatar
Too much chatter, not enough work.
I thought the cones were reusable in Hi-Mod fittings?
Alacrity, 1981 Tartan 33 #168
Ajax_MD is offline
post #5 of 9 Old 01-26-2014
Daniel - Norsea 27
Rhapsody-NS27's Avatar
I thought I read the same thing when I got Hi-Mods for my boat. I believe you can still get the cones and crowns by themselves if you need to. Maybe it depends on any part of them being deformed in any way.
Ajax_MD likes this.
Daniel
1981 Nor'sea 27,
“Who is staring at the sea is already sailing a little.”
-Paul Carvel
Rhapsody-NS27 is offline
post #6 of 9 Old 01-26-2014
Delezynski's Avatar
Location: Currently in Az. and trailer to various places.
From my recent re-rig.....
ALL parts of the Hi-Mod fittings are reusable. No extra parts are normally needed on the next re-rig other than the new cable.
Sta-Lok and Norseman require new parts (cones & .. ) for each re-use.
You can see my install of Hi-Mod fitting on my Youtube page or the video direct at;
*** Note, this video is in 3D, but you can turn that off by going to the bottom and clicking on the small gear then "3D", off.
Greg
downeast450 likes this.
Greg & Jill Delezynski
Nor'Sea 27, Guenevere
Home page -
Youtube page -
Youtube Virtual Reality page -
Delezynski is offline
post #7 of 9 Old 01-26-2014
Chastened
Ajax_MD's Avatar
Good to know, as I just got a box of shiny, new Hi-Mod fittings .
Ajax_MD is offline
post #8 of 9 Old 01-27-2014
I don't discuss my member
zz4gta's Avatar
Greg
+1 I'm a Hayn and CS Johnson dealer and Greg is correct. Hi-mods (Hayn) are the only ones that are completely re-usable (assuming normal use). Sta-loks (CS Johnson) and Norseman require new parts.
Merit 25 # 764 "Audrey"
zz4gta is offline
The Following User Says Thank You to zz4gta For This Useful Post:
Rhapsody-NS27 (01-27-2014)
post #9 of 9 Old 01-28-2014
christian.hess's Avatar
well I just did some norsemans up...they were about 20 years old simple as heck
id use hi mods if I didnt already have 80 percent of the previous rigging done in norsemans TOP AND BOTTOM
so to save a few bucks I went with new cones and called it a day
the issue is to pay attention to whatever terminal procedures you have
if its norsemans its to use loctite on the threads and ample sealant to prevent corrosion...what sealant anyone that doesnt smell like vinegar
if its staloks it to not overtighten....some threads showing is ok
hi mods...get the cones and wires well spaced
others dunno
they are all decent if not great and more BETTA than swaged simply cause you can check status and fix or replace
cones for my 5/16ths wire were less than 10 bucks for each wire...enabling me to replace either wire or all for cheap...
Merit 25 sold...Islander 36 still afloat? who knows...Im still in Columbus, and back...I think...jajajaja!!!!
christian.hess is offline
Sta-Lok? parttimesailor Gear & Maintenance 10 12-03-2010 08:09 PM
Sta Lok system rbtpfe9 Gear & Maintenance 10 11-15-2009 05:31 PM
Sta Lok Pricing winterbuoy Gear & Maintenance 10 05-29-2009 07:17 PM
Sta-Lok or ? killarney_sailor Gear & Maintenance 22 11-06-2008 08:55 PM
Sta-lok reuse lstrong Gear & Maintenance 0 05-08-2004 03:40 PM
