Chainplate craziness - Page 2 - SailNet Community
Advertise Here
Old 01-27-2014
new dad!
christian.hess is on a distinguished road
Re: Chainplate craziness
the ring a bell trick works too bu suspending the plate on a wire(works better on longer plates)
if it rings true by tapping it everywhere you are fine
if there is a thump or dud dead sound smack the plate on the floor and wacth it crumble and break right nefore your eyes...
even if it looks fine on the outside
1973 Islander 36 complete restoration under process!
  #12
Old 01-27-2014
RichH's Avatar
RichH will become famous soon enough
Originally Posted by overbored View Post
dye penetrant testing is a better choice for 300 series stainless. Mangaflux does not work as the 300 stainless because it is not magnetic.
MAGNAFLUX Corp. "ZYGLO" is the principal dye penetrant system used for 300 series stainless.
christian.hess likes this.
You may post attachments
You may edit your posts
Chainplate alloys wkinsey Gear & Maintenance 11 11-26-2010 05:04 AM
Chainplate inspection josrulz Gear & Maintenance 35 05-14-2010 12:22 PM
Leaking Chainplate Sixbrothers Gear & Maintenance 20 06-22-2009 11:03 PM
chainplate fabrication.. groundhog Gear & Maintenance 3 09-16-2008 09:45 AM
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
SEO by vBSEO 3.6.1
