Loos Gauges and Alternative Rig Tuning Methods - SailNet Community
 1Likes
  • 1 Post By azguy
post #1 of 10 Old 01-27-2014 Thread Starter
I would like to make sure the standing rigging on my tall rig Catalina 27 is properly tuned. The goal isn't so much racing but general maintenance/upkeep. The Cat 27s use 3/16 inch and 5/32 inch for the fore/back stays and foward/aft lower shrouds, respectively which requires two different Loos gauges at around $90/gauge.
I've been reading the rigging guide by Selden and considering the folding rule method as it seems like a nice DIY alternative to expensive gauges.
Has anyone successfully used the folding rule approach? Are there other methods?
For what its worth the details on my rig are:
Masthead rig with forward and aft shrouds and inline spreaders
Roller furling on the headstay
NO running backstay
Deck stepped mast
Josh
engineer_sailor is offline
post #2 of 10 Old 01-28-2014
blt2ski's Avatar
Re: Loos Gauges and Alternative Rig Tuning Methods
WHile I will not say it is truly accurate, I have teh same issue with my Jeanneau that is similar in size etc as you C27. I have a PT2, for the wire that is one sized smaller. Using the differences in the larger sizes, I've swag'd the setting for the slightly too small size. When I had a pt1 or equal available, it comes in pretty close. Close enough for my stds. any how! I do race more frequently than not. MY 02 for what 02 is not worth.
Marty
She drives me boat,
I drives me dinghy!
blt2ski is offline
post #3 of 10 Old 01-28-2014
merit 25 solo "er"
christian.hess's Avatar
ive always tuned by hand and feel...but that is not a common way to do it
however I will be doing it this way on my islander 36 down here...
Ill find a write up if you are interested...its a very easy and time honored method of tuning your mast
its easy...and remeber never overtighten...
the good way to do any rig tune is to always test sail in steady(10 knots then 20knots for example) conditions...and then tune(tighten or loosen) in calm flat water with a balanced boat..if your listing cause of half full water tanks or fuel or cans of food on one side your feel or readings will be wrong...
last tip always use a lead weight or carpenters weight to make sure your mast is completely centered
NEVER EVER EVER GO by thread count or number of turns on turnbuckles since you dont know if they are exactly the same length on each side
other than that easy
good luck
Islander 36 no longer for sale...its MINE!
Planning maiden cruise for November-December 2015 to Panama Canal! The planning begins!!!
christian.hess is offline
post #4 of 10 Old 01-28-2014
azguy's Avatar
Try asking around your marina, I did, and found more than one person that was willing to lend their Loos gauge to me. The person actually came down to my boat and helped me through the whole process since I was a new boat owner....
Then I found out the local chandlery lends them out with a drivers license for security...
JimMcGee likes this.
1988 C22 Owner
azguy is offline
post #5 of 10 Old 01-28-2014
I've used the folding rule method and found it did well. However, since I have a foil on the headstay, I was not able to get an accurate measurement on that. It's a masthead rig and I assumed that getting a good adjustment on the backstay would translate to the headstay.
lancelot9898 is offline
post #6 of 10 Old 01-28-2014
The folding rule method works fine to get the initial correct tension on the the rig.
You must start with all wires without tension, a fine time to lube all the turnbuckles before starting to adjust.
It's correct that the headstay / backstay on a masthead rig will balance out.
The same way you only need to use one folding rule when you adjust the shrouds in pairs.
The most common error with rig tension is having the rig set too loose...
This cause unnecessary flexing / movement in the rig with fatigue failures as result.
knuterikt is offline
post #7 of 10 Old 01-28-2014
rbyham's Avatar
I sometimes wonder how close my rig is to correct. It is my first boat and a year ago I knew very little about any of this. When we stepped the mast I assumed that the forestay was key along with getting sidestays exactly equal. Here is what I did. I first rigged the forestay as it is a furler and has no adjustment in it. So my assumption was that the length as I found it on the hard was the same length the PO had taken down 8 years previously. So I tightened the backstay until fore and aft were near tight by feel. Then using a spinnaker halyard I measured and adjusted side to side until exactly equal. I confirmed their being equal by measuring up from the deck to a fixed point on port and starboard stays. Having sailed it a year now and watched mast and forestay carefully all looks straight and no flexing. But I must confess I wonder what a pro rigger would say about my rig and I have heard that a professionally trimmed boat can make a huge difference.
rbyham is offline
post #8 of 10 Old 01-28-2014
Siamese's Avatar
I can vouch for the Selden method. I used it on my Catalina 309. I cut a piece of plastic electric conduit pipe to the required length to use instead of a folding rule. I ground down the lower end of it to just a small tang or tab, to make it easier to measure (using vernier calipers) from the top of the turnbuckle to the end of the conduit. It's a good method.
Siamese is offline
post #9 of 10 Old 01-28-2014
The Selden "Hints and advices" can be found here Hints and advices : Seldén Mast AB
Download and have a look, even if your mast is from another spar maker the information is good.
post #10 of 10 Old 02-02-2014
norahs arc's Avatar
NO running backstay
Deck stepped mast
Josh
In his book "Boatowner's Mechanical And Electrical Manual" (Third Edition Pg 763)
Nigel Calder describes a simple methood of setting up rigging with a tape measure and some tape or a marker. The methood is based on known properties of the material and common engineering.(Use it myself - sometimes called the folding rule methood)
Catalina 27 Aft. galley, dinnet L/O
Update - Sold Norah's Ark Buying A 24'Shark
Saint John NB
Canada
norahs arc is offline
Tuning the rig.... blutoyz Gear & Maintenance 5 06-03-2013 11:04 AM
rig tuning specs needed C27 standard rig PaulRJordan Catalina 4 06-27-2010 08:50 AM
C&C 33 Rig tuning glorydays Gear & Maintenance 1 05-29-2010 04:29 PM
Rig tuning help zz4gta Gear & Maintenance 6 04-23-2009 04:32 PM
Tuning the Rig Dan Dickison Racing Articles 0 03-07-2002 07:00 PM
