Loose Headstay - SailNet Community
post #1 of 3 Old 08-26-2005 Thread Starter
Loose Headstay
Hi,
I had a new headstay and roller furler installed this spring. Over the course of the summer and some high wind days it has loosened a bit. Is this normal and if so how do you tighten it up? Do you need to tighten the backstay or is there a way to access the lower turnbuckle which appears to be covered by the furler drum.
Thanks!
trpopman is offline
post #2 of 3 Old 08-26-2005
Moderator
Jeff_H's Avatar
Loose Headstay
New stays typically stretch a lot. I find that they stretch most on the first month or so and then seem to settle down over the first year of use. I replaced my standing rigging last year and have retuned 3 separate times over the first year vs the more normal once a year adjustment after the rigging has gone through its initial stretch.
Access to the turnbuckle for adjustment is very dependent on the design of the specific furler system and so your question about how to access the turnbuckle should probably be addressed to the rigger who installed your new furler system or to the manual that came with it.
Jeff_H is online now
post #3 of 3 Old 08-28-2005
Loose Headstay
The turnbuckle on my "Hood" furler is up all the way. I will eventually have to tackle the problem from the top and it is a much simpler way as long as getting up the mast is no problem. After removing the stay, assumming you are in very calm waters and your other stays are tight, cut the top eye off with a cutting wheel on a grinder and attach a Sta-Lok to the top of the stay instead at the new desired length. Sta-Loks are great and have more hold than a swag. Remember in cutting to always cut less because you can always cut more. Then either attach a small turnbuckle at the bottem or use the one built in.
onokaya is offline
Outhaul for Loose Foot Main Quickstep192 General Discussion (sailing related) 21 06-06-2011 12:07 PM
Headstay Connection dhough35 Gear & Maintenance 2 06-03-2004 02:45 AM
leaking and loose rudder tube ndsailor Gear & Maintenance 0 08-30-2002 05:06 AM
loose footed or track mainsail soverel28 Gear & Maintenance 5 05-21-2002 04:08 AM
Tartan T27 headstay length hootie Gear & Maintenance 0 10-24-2001 09:34 AM
