Blogs
User Name
Old 09-08-2005
parvenu parvenu is offline
parvenu is on a distinguished road
alternator test - diesel engine
How do I test my alternator to test whether or not it''s charging my battery?
I have a diesel engine (Westerbeke 27).
Someone suggested that I disconnect the positive terminals of my batteries. If the engine keeps running, that means it''s not working off the batteries. Problem with that, in my mind, is that a diesel engine doesn''t depend upon sparkplugs as a gas engine does. So what would disconnecting the terminals tell you?
So any suggestions?
Thanks.
George
Old 09-08-2005
PaulBl PaulBl is offline
PaulBl is on a distinguished road
<So what would disconnecting the terminals tell you?>
Nothing important.
Old 09-09-2005
dman dman is offline
dman is on a distinguished road
Pulling the cable off your battery will blow your alternator if it is working.The current has to go somewhere,even jumping it and running on a dead battery can damage it.If you need to check the alternator, all you need is a voltmeter. Make sure you have a good battery. Start the engine and set the voltmeter on DC voltage. Take the red lead of the voltmeter and put it on the large red wire at the alternator. Put the black lead on the alternator housing. With the engine at high idle, you should have a reading of 14.2 - 14.6 volts. Take the voltmeter to the battery and place the red lead on positive and the black on negative. You should be reading 14.2 - 14.6 volts. If not, you have a wiring problem to the battery. If you do have 14.2 - 14.6 volts and you still have problems, test the battery.Also remember that the diodes in the alternator can flow backwards when they malfunction,draining it when it isn`t running.
Old 10-20-2005
sundown2 sundown2 is offline
sundown2 is on a distinguished road
a real simple test to check an alternator is to take a piece of metal (screwdriver etc) and hold close to the back of the alternator while it is running. If it is producing electricity it will be creating a magnetic field and you will be able to feel the pull on the metal. (be careful not to hit the output post).
The surest way to test output though is with a multimeter ( Radio Shack about $25). with the alternator running check from the output (+) to ground (-). reading should be above 13.5.
Old 10-21-2005
GordMay GordMay is offline
GordMay is on a distinguished road
Goto: CruisersForum.com
and check out “BASIC Alternator Testing”
http://cruisersforum.com/showthread.php?s=&threadid=375&highlight=alternato r+test
Display Modes
vB code is On
Gear case for Universal M30 or Model 5424 diesel engine besodelmar Gear & Maintenance 0 09-22-2005 01:14 PM
slight oil slick in diesel engine exhaust mcagney Gear & Maintenance 1 10-18-2004 11:28 AM
Cat30 Exhaust riser blew up - Engine won''t start E_N_Z_O Gear & Maintenance 2 07-31-2001 06:55 PM
Diesel Engine nancisboat Crew Wanted 0 03-13-2001 08:49 AM
Raw Water in Engine wmwtlw Gear & Maintenance 3 02-25-2001 11:31 AM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
