So you call that a mast repair?? - SailNet Community
 1Likes
  • 1 Post By TQA
post #1 of 10 Old 01-31-2014 Thread Starter
I recently backed out on the purchase of a real nice fixer upper of a sailboat. I already had cash in hand, it was an Albin Express on a trailer for 2k. However the last time I looked it over, I noticed that the base of the mast had evidence of damage. Someone had taken a piece of 1/4 aluminum sheet and shaped it to fit around the bottom 6 or 7 inches of the mast (in two pieces). These parts were then welded to the mast itself and all the areas where the patch had seams in it. The quality of the welds did not look too bad but I've seen better.
However what concerns me is sort of technical. The mast is a relatively thin walled extrusion that relies on it's shape for strength, and it is anodized. Both extrusion and anodization affect the hardness of the aluminum and I'm pretty sure that the extrusion alloy is harder than standard 1/4 inch plate. Especially when it formed so nicely to the shape of the mast cross section, which would indicate that the patch was unannealed, softer than the mast. In the heat affected zone of a weld the properties of all these materials is affected.
I would never trust a weld under these circumstances. I mean for me there is this great possibility of stress cracks or failure at the top of the patch where the mast meets the weld bead. If I had it to do my way I would have cut off the damaged part and modified the deck step, or fabricated a part to fill in the gap that would be secured to the mast with mechanical fasteners.
Any thoughts?? Anyone ever deal with a problem like this. It looks like someone damaged it while they were raising the mast.
Steve523 is offline
post #2 of 10 Old 01-31-2014
Markwesti's Avatar
Re: So you call that a mast repair??
Hard to say with out seeing it in person . The patch didn't need to be in soft cond. to shape it to the mast . Maybe a welding expert could say if the welding damaged the condition of the heat treat of the mast . But on the other hand how long has the patch been on there ? I mean if it's seen use maybe it's OK.
Markwesti is offline
post #3 of 10 Old 01-31-2014
jsaronson's Avatar
I assume the bottom of the mast sits in the bilge and corroded over time. The proper fix is to cut off the bottom of the mast and build a higher step to take up that space. The new step should be non-corrosive and not react to the aluminum.
jsaronson is offline
post #4 of 10 Old 01-31-2014
TQA
Bombay Explorer 44
TQA's Avatar
Bottom of the mast. Corrosion ?
Not much flex there, just a compression load.
I would think it would be fine.
Flybyknight likes this.
TQA is offline
post #5 of 10 Old 01-31-2014
Mast sections can certainly be welded. The spreader bases on Isomat masts are aluminum castings that are welded to the mast. That's right in the middle of the mast section. If the patch was done well, it's probably fine.
SaltyHog is offline
post #6 of 10 Old 01-31-2014
baDumbumbum
bobmcgov's Avatar
Almost impossible to tell the soundness of such a repair. Start with choice of alloy & welding stick (or wire), TIG amperage, annealing.... Welding Alu is not a trivial business, and subsequent heat treating can make all the difference between a great repair & one that fails w/out warning.
That said, if the repair looks moderately competent & hasn't failed yet, it might be fine. Most (tho not all) of the force at that spot is compression, and the Express doesn't experience crazy loads with only 315sqft of sail. (Nifty boat, BTW. Much raced in England. Sails better with meat on the rail.)
You could saw off the repair & build up the deck plate to suit; or you could cast (lost wax?) a metal shoe or build a composite one to sleeve into the mast. You could also likely find a used stick suitable for that boat for around $800. Cut to length.
Buccaneer18, Grainnia
SJ21, Diarmuid
Albin Ballad 30, Fionn
bobmcgov is offline
post #7 of 10 Old 01-31-2014 Thread Starter
Thanks for all the good input. If I find myself back on the market to get a boat and this one is still there, I may go for it.
Steve523 is offline
post #8 of 10 Old 01-31-2014
A picture is worth a thousand words.
MarkSF is offline
post #9 of 10 Old 02-01-2014
mitiempo's Avatar
Welding part of a mast section is not bad unless it is poorly engineered or the welding is improperly done. Tall masts on larger boats (masts over 40' or so) are usually 2 sections, sleeved and welded at the join, as there is a transport size limit on extrusions. As posted the spreader bases are welded on some masts as are masthead fittings on some.
Without knowing how it was done or seeing a picture preferably the repair cannot be judged.
Brian
mitiempo is offline
post #10 of 10 Old 02-01-2014
pdqaltair's Avatar
Mast base in compression? $2K boat? A good outboard cost more than that.
While I could talk about how I would have done it--on a $$$ boat--on a $2 boat I would be thrilled with that repair.
My guess, if the PO bothered to do such a challenging repair, rather than just cutting off a few inches and raising the step, is that perhaps ice froze in the mast and burst the section up a little ways. But I don't know.
Writing full-time since 2014
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is offline
Mast Crane Repair casey1999 Gear & Maintenance 7 12-23-2013 04:40 PM
Mast Repair KnotRight Gear & Maintenance 2 01-28-2013 04:19 PM
mast repair gtunison Gear & Maintenance 4 10-28-2008 09:36 PM
Mast repair wdilibero Gear & Maintenance 2 07-06-2004 10:56 PM
Bent mast repair blpatten Gear & Maintenance 0 08-30-2001 06:08 PM
