How much water is normal? - Page 3 - SailNet Community
 5Likes
post #21 of 30 Old 02-03-2014
azguy's Avatar
Re: How much water is normal?
I'm so happy, I don't get a drop in my bilge.....
1988 C22 Owner
azguy is offline
post #22 of 30 Old 02-03-2014
Old enough to know better
Originally Posted by BubbleheadMd View Post
The "taste test" is inconclusive.
Rainwater running into an engine bilge where the stuffing box drains to, will taste salty.
The "powder test" is much more effective. Buy a cheap rose bush duster from the hardware store, and load it with DE powder (diatomaceous earth, also at the hardware store).
DE powder is very fine, harmless and cheap. Give some puffs of that around your bilges and watch the water trails illuminate like magic.
And it will kill any insects that happen to come on board!
miatapaul is offline
post #23 of 30 Old 02-03-2014
Bradhamlet's Avatar
Our bilge is always wet, no big deal. However I would like it dry and will try a new packing material at next haul out. A few months back a member said he had great luck with a epoxy putty between the flax stuffing. Let you know at next haul out.
Brad
Lancer 36
Bradhamlet is offline
post #24 of 30 Old 02-03-2014
blutoyz's Avatar
I wish my bilge was this dry...4 months for 4 gallons...nice
blutoyz is offline
post #25 of 30 Old 02-03-2014
Chastened
Ajax_MD's Avatar
Brad
Lancer 36
Uh, I wouldn't do that. Use the new goretex packing instead of flax.
1981 Tartan 33 #168
Ajax_MD is offline
post #26 of 30 Old 02-03-2014
christian.hess's Avatar
epoxy putty in a stiffing box?
wtf?
man
ottos likes this.
Merit 25 sold...Islander 36 still afloat? who knows...Im still in Columbus, and back...I think...jajajaja!!!!
christian.hess is offline
post #27 of 30 Old 02-06-2014
No one seems to think it is loose keel bolts? An older boat with a crack line on the keel joint and that leaks from that needs them tightened and the joint sealed at the least! I sealed the joint on my Catalina 27 on the hard and will tighten the bolts In the spring as they are steel and not easy to get a socket on! Good luck.
ahab211 is offline
post #28 of 30 Old 02-06-2014
'81 H22 & '86 Legend 37
90% chance that if there's nothing else obvious, on a Pearson the keel bolts are corroded and started to leak. The keel bolts are vertical out of the top of the keel and IIRC the 3rd or 4th one back on the starboard side has the boat's grounding system attached to it. You'll probably find significant corrosion on that bolt. Can't be fixed in the water. The boat has to be hauled out and drop the keel out.
If you pull the cabin sole plate and see that the nuts and washers are badly corroded, squirt them right away with WD-40 or equivalent, and keep them soaked up for a week or two, to hopefully make it easier to get the nuts off to drop it out. Otherwise they'll be seized solid and an impact wrench will probably just twist them off.
CruisingCouple is offline
post #29 of 30 Old 02-06-2014
Cruising at a snail pace
Originally Posted by lancelot9898 View Post
If you have a keel steped mast, then depending on rainfall and locations of cutouts for the internal halyards that about of water is not surprising.
On my last boat with a keel stepped mast 4 gallons in a few months was normal. One on the reasons I was happy to have a deck stepped mast on my current boat.
Don't blow air up my rear, be useful and blow it at the sails!
Don0190 is offline
post #30 of 30 Old 02-06-2014
Dave_E's Avatar
After going through this recently (and asking the same question), this is my opinion. If your boat is not wood... it should be dry... all the time, UNLESS you have a conventional prop shaft packing (which I understand do drible) or simply have leaks in your boat. The leaks could be anything from the mast to portlights. Your taking on too much water!
Allmand Sail 31 #15 "Traveler"
GOD, Family, career
Dave_E is offline
Normal battery water usage pdqaltair Gear & Maintenance 9 11-26-2012 08:24 PM
Is it normal for the bowl to not fill? jarcher Gear & Maintenance 19 06-11-2009 12:04 PM
Is this normal rake davidpm General Discussion (sailing related) 25 09-29-2008 09:29 PM
Short Keel vs Normal SEAJM General Discussion (sailing related) 1 03-12-2003 02:13 AM
