5200 vs Sikaflex - SailNet Community
 5Likes
post #1 of 12 Old 02-03-2014 Thread Starter
5200 vs Sikaflex
I've used Sikaflex but its been MANY years now, mostly I use 5200. Can anybody give me a comparison between the two? It seemed to me that Sikaflex made a better seal but that may just be the way I remember it
I can't find Sikaflex down here but I'd order some if I thought it might be worth it.
Thanks in advance!
seafrontiersman is offline
post #2 of 12 Old 02-03-2014
sailvayu's Avatar
Re: 5200 vs Sikaflex
There is no silver bullet, before you pick a sealant you need to understand what to use and where.
Understanding Marine Sealants
Capt. Wayne Canning, AMS
sailvayu is offline
The Following User Says Thank You to sailvayu For This Useful Post:
seafrontiersman (02-03-2014)
post #3 of 12 Old 02-03-2014
bljones's Avatar
5200 has no place on a fiberglass sailboat.
miatapaul likes this.
It's 5 o'clock somewhere:
bljones is offline
post #4 of 12 Old 02-03-2014
Delezynski's Avatar
Location: Currently in Az. and trailer to various places.
For what application??
I like Sikaflex (for some applications) MUCH better than 5200. I NEVER use 5200 as I expect some day to have to remove parts from the boat.
BUT, having said that, I MUCH prefer Dolfinite bedding compound for almost all things like ports and hand rails. It's easy to put in and the excess can be removed and re-used. It never hardens so it withstands flexing. I have also used Lifesafe Butyl Caulking Tape for bedding the outside of our chain plates.
Greg
seafrontiersman and capta like this.
Greg & Jill Delezynski
Nor'Sea 27, Guenevere
Home page -
Youtube page -
Youtube Virtual Reality page -
Delezynski is offline
The Following User Says Thank You to Delezynski For This Useful Post:
post #5 of 12 Old 02-03-2014
5200 is pretty much PERMANENT. Do you really want that? Almost impossible to remove
o
xort is offline
post #6 of 12 Old 02-03-2014
Master Mariner
capta's Avatar
5200 is an adhesive, NOT a sealer! If you EVER expect to take it apart, then never use 5200. The next owner of your boat will repeatedly curse the day you were born, if you use it on your boat.
I have seen it tear apart layers the of a fiberglass cabin side, trying to remove ports, and we were using tiny wedges and razor blades to do it slowly and carefully.
Definitely many minus points in the Black Box Theory.
christian.hess likes this.
facebook.com/svskippingstone
Our Videos;
capta is offline
post #7 of 12 Old 02-03-2014
christian.hess's Avatar
why do people constantly say 5200 is permanent non removable etc...
what crap
I can remove 5200 just as easily as any "sealant"
simple razor, acetone and bye bye
yeah of course 5200 can be used to bed keels, and toerails and deck to hull sandwiches but what on earth makes people think its permanent?
never understood this
ps. just used sikaflex for my chainplates and most deck hardware...I also rebedded backing plates and will be doing my window frame with it
5200 is 35 bucks a tube
sicka is 7 bucks a tube
take your pick! ajajja
Merit 25 sold...Islander 36 still afloat? who knows...Im still in Columbus, and back...I think...jajajaja!!!!
christian.hess is offline
post #8 of 12 Old 02-03-2014
mitiempo's Avatar
Christian
With properly prepared surfaces a ballast keel, bedded with 5200, will stay on the boat after the keel bolts are removed. It has excessive adhesion for most anything on a boat, except possibly the hull/deck join. Its adhesion is greater than the adhesion of the gelcoat to the fiberglass structure. If the item of hardware is going to be attached with bolts or other good fasteners you need not glue it on but use a bedding compound that will expand when the hardware moves, as it will.
Sika Flex, 3M 4200, Boatlife, and Butyl are all good at this without damaging the fiberglass when the item is removed.
Brian
mitiempo is offline
post #9 of 12 Old 02-04-2014
TQA
Bombay Explorer 44
TQA's Avatar
5200 is REALLY good as an adhesive esp. on hypalon dinks that are one step from the grave.
TQA is offline
post #10 of 12 Old 02-04-2014
Originally Posted by mitiempo View Post
Christian
my point was REMOVAL...its just as easy to remove a razor and acetone and its good to go...
I just bed my keel hull joinb with 5200 fast cure...Im very familiar with it...just never understood why everybody says its so permanent
its not
sikaflex 1a contruction elastic sealant christian.hess Gear & Maintenance 34 01-04-2014 02:45 PM
Help -- Sikaflex: I'm sick of it and it flexes Bene505 Gear & Maintenance 3 06-21-2010 07:25 PM
Which type of Sikaflex to use? Bene505 Gear & Maintenance 5 05-21-2010 04:22 PM
Sikaflex 291 LOT vs. 3M 4000 UV Arclight Gear & Maintenance 16 03-31-2010 11:57 AM
3M 5200 JDAM Gear & Maintenance 10 08-08-2007 09:14 PM
