Diverter Valve - SailNet Community
post #1 of 2 Old 10-31-2005 Thread Starter
Diverter Valve
I am trying to install a diverter valve in the cooling system on my Yanmar 2GM20 so that I can fill the raw water side with antifreeze for the winter. The raw water cooling hoses are 5/8", but there are no diverter valves that size. Should I use the next size up? Could I still use a 1/2" valve for this application, and plumb up and down as necessary?
drynoc is offline
post #2 of 2 Old 11-17-2005
Chesapeake Sailor
wwilson's Avatar
Diverter Valve
drynoc - does your Yanmar have a raw water strainer at the top of the exhaust elbow? If so, it is possible and very easy to have the engine load itself with antifreeze by filling the strainer bowl a time or two with the engine running between fills. This technique avoids the trouble of the plumbing modification altogether. If you have a helper, fill the strainer bowl with antifreeze - have the helper start the engine and run it only as long as there remains antifreeze in the strainer bowl, then have the helper stop the engine and you refill the bowl and repeat. Generally my Volvo D2-55 will expel the first of the solution after only 3 fills of the bowl. If you shut it down at that time (being sure the bowl has not been emptied) the entire raw water side of the engine will be filled with the antifreeze. The number of fills will vary of course depending on the strainer bowl size and raw water capacity of your engine.
wwilson is offline
Ball valve lubrication TMK2004 Gear & Maintenance 0 05-13-2004 12:11 PM
GATE VALVE drynoc Gear & Maintenance 2 03-08-2004 06:16 AM
Valve clearances for 2GM13 KenD Gear & Maintenance 2 05-05-2003 01:51 PM
Water Heater By Pass Valve MHRitter Gear & Maintenance 2 10-31-2002 10:41 AM
