Old 11-10-2005
Sailor-man is on a distinguished road
Vovo 2020/30 Oil Check
Does anyone have advice on how to get an accurate reading on the dipstick with a Volvo 2020 or 2030.
Should the oil be checked after the engine has been run? How long do you wait ... or should you check cold.
Old 11-10-2005
whoulihan is on a distinguished road
I don''t think it is an issue - as long as you are talking about the engine oil. Hot or cold - should be close enough. Cold might read a bit high and warm a bit low, but not enough to make any difference.
Regards,
Old 11-12-2005
wwilson's Avatar
Chesapeake Sailor
wwilson is on a distinguished road
Sailor-man,
I have a Volvo D2-55 diesel. I agree with whoulihan. You are correct to suspect a difference: Cold, the oil has fully drained to the crank case and could be expected to be a bit higher. In fact the difference between cold and waiting for 5-10 min after shutting down the engine is negligible. From the Operator''s Manual... "Wait a few minutes before checking the oil level to give the oil time to run down to the oil pan."
First Timers Ocean Crossing Check List Viceroy Crew Wanted 108 03-15-2010 03:09 PM
Check My Plotting... 808state General Discussion (sailing related) 4 02-24-2004 02:35 PM
Check my Plotting... 808state Learning to Sail 4 02-06-2004 03:00 PM
Anything new to check out in BVIs since last summer? DuaneIsing Chartering 2 06-18-2003 02:05 PM
Check it out... DavidVaughn Learning to Sail 0 06-17-2002 05:55 AM
