Sail Drives - SailNet Community
post #1 of 5 Old 11-10-2005 Thread Starter
Sail Drives
I have 2 Volvo Saildrives that appear to be pitting. Has anyone had experience with maintaining these? Do they require just a primer? Or an epoxy base coat.
Thanks,
whoulihan is offline
post #2 of 5 Old 11-11-2005
Moderator
Jeff_H's Avatar
Sail Drives
I had a Buhk saildrive for 14 years. When I bought the boat we stripped all of the bottom paint and coated the sail drive with WEST System epoxy. I never had a problem with corrosion for the rest of the time that I owned the boat.
That said, some Volvo saildrives have internal water passages and those saildrives fail from the inside out and there is not much that you can do about it.
Jeff_H is offline
post #3 of 5 Old 11-12-2005
Sail Drives
Volvo-Penta Guide:
http://www.volvo.com/NR/rdonlyres/8A6909A3-80BB-4A1A-B0CF-F17EF5091B96/0/LayingUp_web.pdf
GordMay is offline
post #4 of 5 Old 11-18-2005 Thread Starter
Sail Drives
Hi Jeff - Thanks for the note. Did you strip the saildrive down to bare metal? Not sure I want to take that on, but doesn''t seem that epoxy over a paint base is a good idea.
post #5 of 5 Old 12-04-2005 Thread Starter
Sail Drives
GordMay - Thanks for the link. I have just spent the weekend with my saildrives and have learned a bit. Taken them down to bare aluminum and started over. Probably more than needed, but I wasn''t sure just how these had been treated. So I now have 4 coats of 2 part epoxy primer and will have 3 coats of anti-foul before splashing on Monday. I used all Interlux, as they seemed to be the only one that had a full program for Aluminum.
Best Regards,
Windward performance deseely General Discussion (sailing related) 21 04-01-2012 03:42 PM
Sloop, Cutter or Ketch jsgsail Boat Review and Purchase Forum 17 12-26-2008 03:47 PM
New to Sailing, please Help =) xyris Learning to Sail 19 11-17-2008 09:30 AM
Ketch/Yawl Handling svsymphony Seamanship & Navigation 19 07-05-2008 02:19 AM
Traveler usage? Humpwalker Seamanship & Navigation 22 02-17-2007 11:54 AM
