Solid Vang Installation-C270 - SailNet Community
post #1 of 4 Old 11-24-2005 Thread Starter
I have purchased a Garhauer solid boom vang for my 1994 Catalina 270. There are no instructions with the vang and the fitting for connecting under the boom seems to be the wrong one. Has anyone installed one on their 270 who can give tips. Thanks. Randy
randy22556 is offline
post #2 of 4 Old 12-01-2005
Not a C270, but may help. I put the same one on my Columbia 8.7 ...
http://www.geocities.com/earlylight160/Vang.html
sailr4 is offline
post #3 of 4 Old 12-01-2005 Thread Starter
Thank you for the informative solid vang email. that does help. Did Garhauer supply you with any written material re: installation? I received none but I bought mine through a dealer. If you have anything maybe you could fax it to me or scan and email it??? It sounds like it needs to be mounted on the mast as low as possible, correct? How did you determine where on the boom to mount the bracket? Is there a desired angle or something? Thanks for your time. Randy
post #4 of 4 Old 12-01-2005
Senior Moment
SailorMitch's Avatar
Randy,
Call Garhauer and ask to speak to someone in tech support. They are a most helpful outfit and can give you all kinds of pointers on how to install the solid vang. They also can verify that the attachment plates are correct. Contact info is at www.garhauermarine.com. I installed one on my former boat (P-27) and checked with them first. Their input was invaluable.
SailorMitch is offline
Heaters: diesel or solid fuel? Seagypsywoman Gear & Maintenance 9 12-29-2004 02:22 PM
Spinlock rigid vang deseely Gear & Maintenance 1 01-28-2004 12:40 PM
rigid vang for small sloop or... Any excuse to upgrade. jbarros Gear & Maintenance 2 10-16-2003 02:01 PM
Boom Vang z1nonlyone General Discussion (sailing related) 4 08-22-2003 06:51 PM
Boom Vang z1nonlyone Gear & Maintenance 5 08-21-2003 08:51 AM
