Old 11-28-2005
upnatit is on a distinguished road
Oil pan for Universal Diesel
Hello,
I haven''t asked a question in over a year and am hopeful of a referral.
I have two newport 28''s one is an A4 and the other is a small diesel. The pan on the small universal diesel has a leak. I was going to use JB Weld or an Opoxy to plug it. I would like to do it right and replace the Pan but the local Mechanic charges way too much for the job. I simply need to know where I can purchase the Oil Pan? I may need to remove the motor or at leasst jack it up.
Any thoughts or referrals for me. My boats are in Long Beach, CA at Shoreline Marina.
Thank you....
Old 11-28-2005
SailorMitch's Avatar
Senior Moment
SailorMitch will become famous soon enough
Try www.marinedieseldirect.com. That''s the site for Torresen Marine, which is a Universal dealer (among other engines.) You can probably find the part online.
Old 12-29-2005
anthonie is on a distinguished road
I have the same problem on my M25. I''ve ordered a new Kubota pan from Tractorsmart.com for $35. I will need to attach the old oil dipstick to this pan as the Kubota comes without it (in this location)
I''ve not got around to pulling the engine out yet, so we''ll see is it is at all feasable.
Let me know the route you went
Tony
Old 11-24-2011
sailkeys92 is on a distinguished road
Hey,
I'm looking for a new oil pan for a Universal M-35... I haven't been able to find one online. Is there a Kubota or Westerbeke engine similar enough to switch out? Thanks,
-Trent
Old 11-25-2011
CalebD's Avatar
Tartan 27' owner
CalebD will become famous soon enough
Did you check Torreson Marine? Sailboat Supplies, Engine Parts and Boat Parts
Old 11-25-2011
eherlihy's Avatar
Finally found the needle!
eherlihy is on a distinguished road
I purchased a used Kubota Oil pan for my Universal M25 from eBay. Total was $25 including shipping. The pan arrived in great shape. However, I will need to drill a hole in the side of the pan to accommodate the dipstick, and drill and tap two holes for the dipstick pipe.
The Kubota part number is 15371-01614
Old 11-25-2011
LakeSuperiorGeezer's Avatar
LakeSuperiorGeezer is on a distinguished road
May want to paint the new oil pan to prevent corrosion. For ideas use a search engine on keywords: paint steel sailboat
Old 11-25-2011
JimsCAL's Avatar
JimsCAL is on a distinguished road
Universal diesels are marizined Kubota engines. Not sure what engine the M-35 is. The engine number MAY be on the dipstick. Look for a nunnber something like Z-500, etc. With that you can go to a Kubota dealer and buy the part for much less than from Universal.
Diesel Stoves santeana Provisioning 6 02-26-2012 05:14 PM
fuel consumption gas vs diesel jklewissf Gear & Maintenance 19 09-12-2009 09:01 PM
installing duct system for diesel heater and air conditioner levenezia Gear & Maintenance 1 09-25-2004 03:20 AM
Diesel Deckplate ERUPTION pma_foyl General Discussion (sailing related) 1 07-06-2004 07:16 AM
diesel tachometer diesel MHRitter Gear & Maintenance 1 09-17-2002 11:52 AM
