Yanmar 2GM20F - Page 2 - SailNet Community
Blogs
  #11 (permalink)
Old 07-05-2008
fullkeel7 is on a distinguished road
Note to self with palm of right hand to center of forhead: SMACK! Before typing a 5 min. reply, check the date of the original post! SMACK! SMACK! How many times do I have to do this before I learn....SMACK! OUCH!! Da..!
  #12 (permalink)
Old 07-06-2008
MedSailor's Avatar
"Fairhaven" Formosa 41
MedSailor is on a distinguished road
It's funny, the old timers tell the folks who are new to sailnet "Have you tried a search on this topic? It's been discussed a million times." Nobody tells them to also check the date....
Old thread, but good info. If my diesel starts acting up as stated I'll remember some of what I read here.
MedSailor
BTW I had a yanmar 2QM20 I thought they ALWAYS vibrated like that.
"True, your boat will outperform mine to windward, but my boat will always outperform yours at anchor." --MedSailor
  #13 (permalink)
Old 07-07-2008
gsyversen is on a distinguished road
if it drops one cause of air that would be permanent though right, mine works just fine during normal use, its just switching from forward/reverse to neutral and just for I'd say a second...
What's wrong putting in a great suggestion to an old original post, I try to search archive before posting and this was exactly on my topic so why start a new thread....
  #14 (permalink)
Old 10-02-2009
roline's Avatar
Cal 9.2 SilverSwan
roline is on a distinguished road
Idle on the 2GM20 should be around 800 RPM. Lower and it vibrates, shakes and sounds like the pistons are ready to launch. I don't like to have it much higher believing it is hard on the transmission when shifting in, out of gear. There is an idle adjustment screw that you can use to adjust the idle to make it independent on cable stretch.
Cal 9.2 #19 SilverSwan
Yanmar installation manual prussell Gear & Maintenance 9 12-14-2007 05:53 PM
Yanmar vs. Perkins skiakhokie Boat Review and Purchase Forum 2 06-29-2004 08:20 AM
Yanmar YSE(?) 8 overhauled 6 year jb2of3 Gear & Maintenance 5 05-02-2003 01:47 PM
Yanmar (3GM 20hp) Blue Smoke Problem animaashi Gear & Maintenance 3 11-05-2001 07:18 PM
Yanmar engine startup smoke WillS Gear & Maintenance 4 08-23-2001 05:42 AM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
