Water hose - SailNet Community
Blogs
Old 12-20-2005
Danielle is on a distinguished road
Water hose
Hey everyone,
my water hose keeps popping off of my hot water tank and it''s driving me bonkers. I have 2 clamps on it and it still pops off. Just today (I am home sick) I had to go out into the freezing cold, (up here at Constitution Marina in Charlestown, MA) shut the main water off, then reconnect the hose and tighten the clamps 3 times before I decided to just keep the water off for the day.
Does anyone have any suggestions on how to keep this bloody thing connected?
Thanks (in advance) ever so much!
Old 12-24-2005
Dave A is on a distinguished road
Water hose
Danielle - I haven''t seen the problem but from here it sounds as if the hose is too large or is old and hard. The hose should be difficult to push over the nipple that you''r connecting to, usually requiris a lot of effort or warming the hose to get it on. Usually there is a raised (bump)on the pipe your connecting to, the hose clamp goes behind the bump and won''t slide off. If the hose is so old and hard that the clamp can''t squeeze it down then it won''t stay on.
It''s hard to say what your problem is without being there, I''m guessing that a new hose of the proper size is needed.
Dave
S/V Windsong
Pearson 35
Old 12-24-2005
Sailormon6 will become famous soon enough
Water hose
I chartered a boat that had an engine cooling hose that popped off repeatedly. The hose had wire reinforcement woven into it, and the wire made it feel like the clamps were tight, when they really weren''t. I had to tighten the hose clamps even more, to crush the wire slightly, so it would seal tightly around the fitting.
Try tightening the clamps more.
Old 12-24-2005
Petar is on a distinguished road
Water hose
Hi,
I believe it might be the old hose. You must also check the condition of the pipe you aree connecting the hose to. If it is cracked it will collapse with tightening.
regards
Petar
MacGregor 26 vs. ? jiml2p Boat Review and Purchase Forum 184 08-30-2011 09:10 PM
Windward performance deseely General Discussion (sailing related) 16 01-28-2010 07:16 PM
water ballast musolmar Boat Review and Purchase Forum 8 09-26-2004 05:50 PM
what about water balast ? AbelCasillas1 Boat Review and Purchase Forum 10 08-15-2004 07:07 AM
removing orig water tank zeilfanaat Gear & Maintenance 6 04-12-2004 07:26 AM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
