stantions - SailNet Community
post #1 of 3 Old 12-22-2005 Thread Starter
stantions
I need three stantions and one stantion base for a Pearson 323. Pearson used the same stantion on several models: Stainless steel, 30 inches tall, one inch tube, rounded top, hole in top only, no lower lifeline hole.
Please advise any availability or sources.
Thanks,
Jim Ellis
jandkellis is offline
post #2 of 3 Old 12-22-2005
Senior Moment
SailorMitch's Avatar
stantions
Two possible sources are www.topsinquality.com and www.garhauermarine.com. If those don''t pan out, email me directly and I can put you in contact with a P-323 owner who should be able to help you. His boat was extensively damaged in Isabel a couple of years ago and he had to replace nearly everything on deck.
SailorMitch is offline
post #3 of 3 Old 12-23-2005
stantions
Also check out sailorman in Florida. After this last year they may have a lot these stanchions in stock.
Irwin32 is offline
Original Stantions for Cal 2-27 Schooner4 Gear & Maintenance 2 11-26-2003 11:09 AM
Backing Plates for C&C34 Stantions fesivo Gear & Maintenance 3 01-20-2001 10:28 AM
