Isotherm frig - Page 2 - SailNet Community
post #11 of 11 Old 02-14-2014
One of None
deniseO30's Avatar
Re: Isotherm frig
Philsmith32 We need allot more information. age, model number, locaton of unit, ambient operation temp, etc. IF you hear gas in the plate and it's not getting "sticky cold" Meaning cold enough that your finger sticks to the plate when you touch it after about an hour. It could be refrigerant. Most of these little systems use very small amounts of refrigerant. (around 5 oz +-) Most DIYs make more problems then they fix. since just the 3 hoses on the gauges hold 3-6 oz of gas alone. The leak; if there is one, is most likely at the "quick connect" fittings. You could have a dirty condenser, intermittent fan, short cycling from power problems to module problems.
Originally Posted by capta View Post
There should be a sight glass somewhere in the system. If you see a few bubbles passing, that's OK, but if you see foam, then you have a problem.
Sight glass? Not likely, Larger units with engine mounted compressors may have a sight glass
My last project!
deniseO30 is offline
Tags
frig , isotherm , refrigeration
Isotherm refrigeration motovationcycles Gear & Maintenance 6 10-06-2009 09:45 AM
Nova Kool R2600 Frig riburton General Discussion (sailing related) 1 09-14-2009 12:16 AM
Did I kill my frig?? uwyoda Gear & Maintenance 17 01-25-2009 12:02 PM
Marine Frig tech needed NewsReader Mass Bay Sailors 0 07-02-2007 02:15 PM
Frig tech needed NewsReader Mass Bay Sailors 0 07-02-2007 11:15 AM
