Blogs
User Name
Old 12-28-2005
shmangasarian shmangasarian is offline
shmangasarian is on a distinguished road
refinishing aluminum rub rail
After a number of tough years the aluminum rub rail is looking pretty scarred. I''m fairly confident about sanding and polishing out the worse bits, but I''m seeking suggestions for how to refinish it. The ultimate solution is to remove it and have it anodized again, but can anyone recommend perhaps a hard epoxy coating I can use after an etching primer. thanks in advance.
chefmango
s/v Enfin, Oxford MD
Old 01-13-2006
merc2dogs merc2dogs is offline
merc2dogs is on a distinguished road
I''d say use a clear epoxy paint or even varnish, though anything ''painted'' on is going to require periodic upkeep because it will chip off.
Having something as large as that anodized would be expensive, but it can be done at home if you have the room.
either dig a trench in the yard, or build a trough with 1x lumber and line it with plastic sheeting, build it to be able to cover the entire part, fill with your chosen solution and hook up the anodizing leads. sealing afterwards can be done with a steam gun, or hook up a pump to circulate very hot water from a boiler/water heater
ken.
Display Modes
vB code is On
Toe Rail Issues sjacovino Gear & Maintenance 9 11-25-2004 09:08 AM
cleaning aluminum water tank rbtpfe9 Gear & Maintenance 6 04-12-2004 07:08 PM
painting anodized aluminum mroskothen Gear & Maintenance 1 08-13-2003 02:51 PM
Toe Rail for a Ranger 28 demcshan Gear & Maintenance 0 05-27-2001 09:48 PM
Aluminum Rail DirtManly Gear & Maintenance 0 05-01-2001 05:17 PM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
