dinghy outboard- brands? - Page 2 - SailNet Community
post #11 of 13 Old 01-09-2006
I throw my lot in with the Yamaha as well, one pull, always starts, beginning of season, end of season.
shmangasarian is offline
post #12 of 13 Old 01-20-2006
as far as 2 strokes, the 9.9 & 15 hp are the same engines with different carbs on most brands, so same weight. met a fellow in keys who offered to trade his newer 4 stroke even for my 2. almost did till considered weight of the 4. too much for practical moving up & down from rail. yamaha has more power than merc in 2 stroke, but a little heavier.
westerly84 is offline
post #13 of 13 Old 01-20-2006
Seņor Member
TrueBlue's Avatar
You''re correct . . . both the Yamaha 2-cycle 9.9hp and 15hp, have the same weight of 79 lbs. Interestingly, the weight difference between Yamaha 4-stroke 9.9 (91 lbs) & 15hp (99 lbs) is 8 lbs - almost insignificant.
I suppose the 20 lb difference between 2-cycle & 4-stroke is considerable, if removing the engine from the dinghy is done often. Regardless, I''m going with the 99 lb 15hp model. It''s very difficult to pass up the deal I found on this boat/motor package. My mizzen boom also makes a great motor crane.
TrueBlue is offline
Outboard motor controls waltzingmatilda Gear & Maintenance 3 05-05-2010 09:08 AM
Outboard: Buying, Type & Fitting omega001 Gear & Maintenance 11 11-10-2006 10:09 AM
Hard dinghy dock storage DWrate Gear & Maintenance 1 12-13-2004 03:39 AM
What new dinghy should I buy? jbr Racing 10 02-26-2004 03:03 AM
Input wanted re: new dinghy jbr General Discussion (sailing related) 2 02-18-2004 08:55 AM
