Stepping mast single handed - SailNet Community
post #1 of 15 Old 01-07-2006 Thread Starter
I have an S2 6.9 and searching for a safe ande easy way to step the mast alone. Any ideas?
Glyle is offline
post #2 of 15 Old 01-09-2006
http://media.putfile.com/maststep
Bawgy is offline
post #3 of 15 Old 01-10-2006
I don''t remember exactly how the S2 is rigged, but, if you look carefully, you can find about four mast raising systems by going to the following web address.
http://www.catalina25-250.org/tech/tech25/tech25.html
I''ve never used any of these systems, but know people who swear that the system they use can be done single-handed. Personally, I''d feel better having one person to keep the mast from swinging from side to side while it''s going up.
Sailormon6 is offline
post #4 of 15 Old 11-18-2006
I came across this, which you may want to look at, I am:http://home.att.net/~sail-trailers/mastlift.html
D
dhendry is offline
post #5 of 15 Old 11-29-2006
stepping the mast by yourself
Howdy yall!
I'm a sailing instuctor here in central Texas, and I get lot's of questions on how to step the mast by oneself. There are many systems for doing so already developed for various boats, so I've been filming them so yall can see how it's done on various boats. I put these videos on my website, Sailing Texas, and there is no charge to see them. As you will see, for a sailboat that steps on the deck instead of down on the keel the methods are all very similar. Something to keep the mast from falling sideways and then a method to pull the mast up using a lever. In the latest video my wife Alison (who weighs 120 pounds and is 56 years old!) raises and lowers the Flying Scot mast entirely by herself. She said it was very easy.
Here's a link to my Videos page, which has a lot of interesting stuff, one section is devoted solely to raising and lowering masts,
http://www.sailingtexas.com/Movies/s...deosindex.html
I really hope this helps. Raising and lowering the mast can be very easy, and if done properly is quite safe too.
Luckenbach
Luckenbach is offline
post #6 of 15 Old 11-30-2006
I like the A-frame setups better than the single gin-pole setups, as I believe they're easier to work with and far safer. On my friend's Cape Dory, they use the boomvang and attach it to an A-frame, made of 1" pipe, and the forestay chainplate. The jib halyard is attached to the A-frame and cleated off so that the A-frame is roughly vertical. The mast foot has a pin that goes through the mast step base and then, once the pin is in place, they haul on the boom vang to raise the mast. It works pretty well and could be done by a single person, but generally they have two people doing it.
sailingdog is offline
post #7 of 15 Old 02-27-2007
no luck reaching sail-trialer
D
I went to that web site and tried calling the number. I sent an e-mail and received no response and I tried telephoning the number but it is apparently disconnected.
loomaz is offline
post #8 of 15 Old 02-27-2007
Mast raising system
Do you know where I can buy an A-frame setup or plans to make one. I have a Rhodes 18 that steps on the keel so the mast needs to be raised verticle and dropped into the hole in the foredeck.
loomaz is offline
post #9 of 15 Old 02-27-2007
2kt wind=trolling speed
goose327's Avatar
Originally Posted by Luckenbach
Howdy yall!
Luckenbach
Luckenbach, thank you Sir,, SOOOO much. You have solved my biggest problem.
I have to tell you, your site(SailingTexas) was one of the first I found when I began my search for a boat, and I go on almost everyday just to see what's new in the "for sale" section. The gallery is one of my favorites. Again, thank you VERY much, I feel like I'm a better sailor today.
goose327 is offline
post #10 of 15 Old 02-27-2007
mast raising video
I went to the site and tried to play the videos but all three show only the construction of the device. The videos showing the actual raising and lowering of the mast just repeat the first one.
loomaz is offline
Deck stepped Mast-Always Bad ? Mrs Mutiny Boat Review and Purchase Forum 24 10-05-2009 07:55 PM
which 38ft boat? bluewaterdreamer Boat Review and Purchase Forum 10 10-03-2007 12:54 PM
30ft Catalina BigRuss Boat Review and Purchase Forum 3 09-09-2006 05:33 PM
what mast? jrwright Boat Review and Purchase Forum 3 03-14-2004 08:19 PM
Is one better than the other? gandydancer Gear & Maintenance 7 07-11-2002 06:08 PM
