Something to hold tiller in place - Page 2 - SailNet Community
 3Likes
post #11 of 21 Old 02-14-2014
Siamese's Avatar
Re: Something to hold tiller in place
I have used the Davis, and it's alright. I'm currently using the Wave Front Tiller Clutch (as mentioned by a previous poster) on my Precision 23. The tiller clutch is vastly superior to the Davis. It sets instantly and releases instantly. Very easy. It's really one of those devices that's so good, you wonder how you got along without it.
Lubrdink likes this.
Siamese is offline
post #12 of 21 Old 02-15-2014
One more vote for the wavefront tiller clutch. When using the tiller extension you can clutch and clutch with your toes as well.
Rumen
olianta is offline
post #13 of 21 Old 02-15-2014
Captain Obvious
Sal Paradise's Avatar
A bungee chord wrapped around the tiller and hooked port and stb will work.
Sal Paradise
Senior Researcher - Dunning Kruger
Sal Paradise is offline
post #14 of 21 Old 02-15-2014
I vote for the wavefront tiller clutch as well.
Marc Hall
Crazy Fish - Maintaining, Upgrading and Sailing a Crealock 37
MarcHall is offline
post #15 of 21 Old 02-24-2014
Learning a bit every day
FinallySailing's Avatar
I've unfortunately not seen it available here in the UK (or should I say luckily, otherwise I would have another job to do on my wish list): I quite like the idea of the Forespar extendable tiller extension that can be locked in the cockpit coaming with its proprietary tiller lock.
Forespar - TILLER LOCK BOX - FOR100000
Yet my heart hammers now, yearning anew
wanting the steep salt-water road
longing with lust to roam rough seas, alone
to seek out some far foreign shore
From "The Seafarer", an Anglo-Saxon 10th century manuscript.
FinallySailing is offline
post #16 of 21 Old 03-07-2014
Samuelmonosov's Avatar
An icicle hitch tied to the tiller, then looped around a deck cleat makes it easy to control the rudder from anywhere on the boat. I've actually gone below and made a sandwich all the while staying in course by just pulling and giving in the line.
Sent from my iPhone using Tapatalk
Samuelmonosov is offline
post #17 of 21 Old 08-25-2014
A perfect day!
chrissailorman's Avatar
Just tried the "Cajun tiller tamer" today. Light to moderate winds just around 10 kts. Also worked for holding course while using the outboard allowing you to put things in order on returning to marina. Simply a line, 3/8, tied from stern cleat to tiller with three turns around tiller from beneath, the tied other end off on the other stern cleat. You tube has a video that shows it very well. I'm impressed. Ultimate in simplicity and when you want to let it off, simply slide the coil to the rear of the tiller. Worth a try. Can't beat the cost!
Chrissailorman
1987 Rhodes 22, Blue Hawaii
Blue Point, N.Y. Great South Bay
chrissailorman is offline
post #18 of 21 Old 08-26-2014
asdf38's Avatar
I just use a line tied off to each side with adjustable slip knots.
Specifically I have an alpine butterfly to loop around the tiller (this is a type of loop in the middle of a line) and an adjustable grip hitch tied through U bolts on each side which I can slide up and down to adjust tension.
Using this line is typically my preferred upwind sailing strategy and when properly adjusted it sails the boat better than I can can.
I'd suggest rigging up some kind of line and seeing how you like it. You may find a new piece of equipment unnecessary.
asdf38 is offline
post #19 of 21 Old 08-27-2014
TQA
Bombay Explorer 44
TQA's Avatar
I used this as a way of holding the tiller at any angle.
Vertical pin in the tiller mid way. I used a piece of 5/32 brazing rod.
String chain string. The chain needs to be sized to allow the pin to go through any link.
Tie the string chain string in such a way as it lies across the tiller about 1/2 way up the tiller.
When require drop chain onto pin.
Strong bungee can be used instead of string, this allows the boat to round up some if getting over pressed.
Both worked for me on a Catalina 22
Cheap as chips.
TQA is offline
post #20 of 21 Old 08-27-2014
I prefer the TillerClutch because of the very fast, simply-made adjustments that can be done with one hand. I tried the home-made rigs. They worked fine in light air when I had the leisure to futz with it until it was just right and I wanted the boat to sail while I ate a sandwich and a beer while sitting close to the tiller. But they failed me when things were more critical and I needed to make small adjustments in a dynamic situation (choppy, gusty, sail set adjusments, etc.).
"Also worked for holding course while using the outboard allowing you to put things in order on returning to marina." This works for me using the rudder tiller and locking the outboard steering to straight-ahead, but it reduces the effectiveness of the rudder. I've read some descriptions of connecting the motor to the rudder/tiller so that the two will move in tandem. I might try doing that to my boat someday when I have more time to rig it up. In other words: highly unlikely.
jwing is offline
To Have and To Hold (anchoring) GoodOldBoat Good Old Boat 7 05-23-2015 06:38 PM
Lashing/holding tiller wheel in place jcshipley General Discussion (sailing related) 9 12-11-2013 01:11 PM
Advice for repair of tiller pilot->tiller connection jgsteven Gear & Maintenance 2 09-11-2009 04:53 PM
Hold your course? GreatWhite Racing 64 07-02-2009 11:05 AM
Hold That Line Tom Wood Gear and Maintenance Articles 0 10-03-2002 08:00 PM
