Spinnaker sheet lengths - SailNet Community
post #1 of 7 Old 02-15-2014 Thread Starter
OUPV 25 Ton
CaptainRahnn's Avatar
Rigging my spinnaker and was wondering how long and what diameter my spin sheet lengths should be approximately on a Cal 34
Thanks
1976 Cal 34 mk2
"Shameless"
CaptainRahnn is offline
post #2 of 7 Old 02-15-2014
MarkofSeaLife's Avatar
Dock
Re: Spinnaker sheet lengths
One and a half times the boat length, if I remember corectly
Sea Life
Notes on a Circumnavigation:
MarkofSeaLife is offline
post #3 of 7 Old 02-15-2014
One and a half times boat length and a diameter that is comfortable to the hand. I use 3/8" New England VPC. It is a vectran core and polyester cover.
SJ34 is offline
post #4 of 7 Old 02-15-2014 Thread Starter
OUPV 25 Ton
Some one told me twice the boat length plus 10ft. 78 ft seems like a lot but I don't want to come up short.
1976 Cal 34 mk2
"Shameless"
post #5 of 7 Old 02-15-2014
What type of spinnaker?? if you're planning on 'outside gybing' an Asymmetrical 1 1/2 boatlengths might not do it.
If you plan to douse the spinnaker into the cockpit with control then measure from the back end of the cabin, back through the aft turning block, forward around the boat outside all standing rigging, back to the cockpit and add 10 feet. That way you can douse, and later reset without having to re-run the sheets all over again.
Faster is offline
The Following User Says Thank You to Faster For This Useful Post:
CaptainRahnn (02-15-2014)
post #6 of 7 Old 02-15-2014 Thread Starter
OUPV 25 Ton
Symmetrical,.... dousing will depend on the situation. I would like the option to douse in the cockpit if necessary.
Thanks
1976 Cal 34 mk2
"Shameless"
post #7 of 7 Old 02-15-2014
blt2ski's Avatar
!.5 times per length should work. I use about 3.5 times for AS sheets doing outside gybes tied in the middle. I also use as small and light wt sheets as I can get away with. So during really light wind days, ie under 5 the spin will fly. My 3/8' sheets were horrible for those days. where as the 3/16" one work great. THey are with in 400 lbs of breaking strength of the 3/8" ones, ie a bit lighter.....but work fine in winds upwards of 15-20 knots. Altho in these winds, the 3/8 are nicer from a hand point of handling.
Marty
She drives me boat,
I drives me dinghy!
blt2ski is offline
Tags
length , running rigging , sheets , spinnaker
Do I need a guy and a sheet on each side of spinnaker? matthewwhill General Discussion (sailing related) 30 03-21-2013 05:49 PM
PSC 31 sheet/halyard/line lengths AlLorman Pacific Seacraft 11 04-22-2012 11:21 AM
Spinnaker sheet routing jarcher General Discussion (sailing related) 7 03-26-2010 07:01 PM
Spinnaker sheet barber haulers metch Racing 8 09-08-2009 08:49 PM
Stay lengths for Tanzer 28? tanzer Tanzer 0 04-05-2009 05:38 PM
