Blogs
User Name
Old 01-10-2006
offline2004 offline2004 is offline
offline2004 is on a distinguished road
Winterizing Yanmar 27
After paying entirely too much AGAIN to winterize the engine on my Hunter 336 Yanmar 27 I have determined that it is time to learn more than where the diesel goes...
I guess like many boat owners I am painfully realizing that the cost of owning a boat is not the cost of buying the boat.
Can anyone recommend any materials (books or websites) that might have "marine diesels for dummies" type of materials including oil changes and winterization...
Thanks
Matt
Old 01-10-2006
SailorMitch's Avatar
SailorMitch SailorMitch is online now
Senior Moment
SailorMitch will become famous soon enough
An excellent place to start is www.marinedieseldirect.com, which is the website for Torresen Marine, a Yanmar dealer. They have a bulletin board for posting questions for one thing, and also sell all the factory engine manuals, etc.
I have a Yanmar 2GM20F and there isn''t much to winterizing it at all. It''s easily something you can take care of.
Old 01-11-2006
Irwin32 Irwin32 is offline
Irwin32 is on a distinguished road
I found a manual for Yanmars from some company on E Bay for $20 and bought one. It is designed for do it yourselfers with very clear instructions and photos. I can''t recall just how detailed it is in regards to winterizing, but I think it is worth having along. It does do a good job explaining how to do an oil change. I''d check for you but it is up on my boat which I won''t be visiting for a week or so. It is not the factory book, but for people like us it is probably better.
For oil changes, I had been using a par hand pump. the kind with the brass body. It took a lot pumping to get the oil out. This year, I decided to try a new system by Tempo. It is a cannister. Once the tube is inserted in the dipstick hole you pump the air out of the cannister and then go do something else while it sucks the oil out. When it is done, disconnect the hose and take the cannister to the recycle tank. I have used it only once and was impressed.
Old 01-11-2006
thanks!!!
I also found a book from Don Casey on Sailboat Maintenance that appears to have a good section on "marine diesels for dummies"
Matt
"Offline" - Herrington Harbour, MD
Old 01-11-2006
Senior Moment
I have both the Clymer Yanmar Shop Manual, and the official Yanmar Service Manual. It may be overkill, but I find both good references. The Yanmar manual is more complete. I''m far from a diesel mechanic and need all the help I can get.
Mr. Offline2004 -- would you mind correcting the spelling of Jimmy Buffett''s name in your tag? Thanks! Jimmy would like that.
Old 01-12-2006
SailorMitch
If you wouldnt mind telling me where I spelled it wrong I would gladly correct, but to the best of my knowledge including on more ticket stubs than I can remember it has always been spelled "Jimmy Buffett".
Thanks for the input... Where on the Chesapeake are you out of?
Old 01-12-2006
Senior Moment
You had spelled it with one "t" in your prior posts. Thanks for going back and correcting it. I didn''t mean to sound snippy. I stopped going to his concerts because Nissan Pavilion is such a pain when trying to leave. It was much more convenient when he used to appear every year at Merriweather Post in Columbia.
I sail out of the Patapsco.
Old 02-17-2006
Denr Denr is offline
Senior Nappy Headed Ho
Denr is an unknown quantity at this point
Sailormitch does have a short fuse, he has ripped others a new one on theses boards, watch him!
Display Modes
vB code is On
Yanmar installation manual prussell Gear & Maintenance 9 12-14-2007 04:53 PM
Stolen Yanmar 1-GM-10 Impulse 26 Gear & Maintenance 0 09-09-2003 08:39 PM
Yanmar 2QM15 Bleeding Fuel System - HELP shipley Gear & Maintenance 5 03-11-2002 07:21 PM
Yanmar (3GM 20hp) Blue Smoke Problem animaashi Gear & Maintenance 3 11-05-2001 06:18 PM
Yanmar 2QM15 Problem shipley Gear & Maintenance 5 05-18-2001 09:17 PM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
