Plugged cockpit drain - SailNet Community
post #1 of 15 Old 02-15-2014 Thread Starter
rbyham's Avatar
Starboard cockpit drain is plugged. I have tried reaching down in with carious flexible tools but no joy. Anyone have an idea short of complete disassembly? I was thinking to ask my diver to try from below...
rbyham is offline
post #2 of 15 Old 02-15-2014
Life is a wild ride!
Dean101's Avatar
Re: Plugged cockpit drain
When I bought my first boat and gave it a good scrub down, I noticed one of the drains was clogged. It turned out to be accumulated dirt and debris in the hose. I shut the seacock, removed the hose, flushed it and replaced. The drain worked like a champ after that.
Hope that helps.
Edit: You could try pressurized water or air but it wasn't difficult to remove the hose on my Endeavour. Your boat may be different though.
Dean101 is offline
post #3 of 15 Old 02-15-2014
If you have a functioning through hull valve, close it, remove the hose, clean it out and test the valve to see if water backflushes through.. if the hose is clear that might help clear the valve out if the debris in there. If you physically see gunk on the top of the valve, loosen/dig it out with a piece of welding rod or some other stiff wire, then flush.
Good to know, in any event, if your through hulls actually move, and more to the point, if they actually shut off and don't leak....
If you want to try clearing it without disassembly first, try a wet/dry shop vac from in the cockpit...
Faster is offline
post #4 of 15 Old 02-15-2014
Is there a seacock ? if so..is it a gate valve?
tempest is offline
post #5 of 15 Old 02-15-2014
flo617's Avatar
I have a drain that gets periodically clogged. I need to see if something is not growing in there.
In the meantime I plug my shop-vac to the hole. A small burst is enough to unclog it. Watch out as it will suck water out too.
flo617 is offline
post #6 of 15 Old 02-16-2014
use a plumbers plunger like you'd use for a toilet
I'm not happy unless I'm complaining about something.
I'm having a very good day!
misfits is offline
post #7 of 15 Old 02-16-2014
Rent a plumber's drain auger?
Personally, I would disassemble, but an auger should work.
Jeanneau 54DS
Minnewaska is offline
post #8 of 15 Old 02-16-2014
You'd get a drain auger stuck then you would be disassembling it.
Flo617 suggested a shop vac, instead of vacuuming it out, reverse the hose & blow it out.
misfits is offline
post #9 of 15 Old 02-16-2014
deltaten's Avatar
Send a message via Yahoo to deltaten
When mine slow or stop, I use an electrician's fish tape to clear; then the dock hose to flush the small debris. I'm planning on enlarging the scuppers/hoses this coming season. They are only 1/2"aperture now, with5/8 hose exiting the transom. Spring and Fall tree debris needs clearing a couple times a month! 1 or 1 1/4" hose may rectify that clogging?
S/V Chrysalis
'80 Watkins 27
North East, MD
deltaten is offline
post #10 of 15 Old 02-16-2014
The best way i have found to un plug these is to blow them out from the opposite direction. If there is any way to blow pressurized water from under the boat up, i'd try it. Be careful useing compressed air, water, auger's as you could do some damage. The vacuum may work though.
benesailor is offline
Cockpit drain holes Baloo_it Gear & Maintenance 8 06-16-2013 09:22 PM
Cockpit Drain Line sct5566 Gear & Maintenance 2 04-14-2012 02:09 PM
Cockpit drain question benajah Gear & Maintenance 13 03-28-2012 01:34 AM
mac 25 cockpit drain. jhnblngr MacGregor 4 06-18-2009 12:00 AM
cockpit drain clog Loualfr Gear & Maintenance 4 05-28-2004 03:51 AM
